2 Re: headlight Sun Jan 18, 2015 4:38 am
Number of posts : 7967
Low beam should work without engine running but only if lights are turned on.
All lights, indicators, brake lights etc should work when you have ignition switched on and the kill switch set to live but without engine running. When you press the starter button the load shed relay kicks in and disconnects them while the starter is turning, as soon as it fires they will come on again.
What is the status of your lights when the engine is not running?
Good luck with the renovations too, hope we might see you out soon....
1971 Yamaha 125 YAS-1
