1 New Member sort of Tue Mar 29, 2016 8:57 pm
yamaguzzi
Hi,I joined this forum about two years ago when a friend gave me a 1988 K 100 .It is a nice bike with only 12000 miles on it but hasn't run in over 12 years.I got sidetracked with other projects but the other day I found my way back to the K.I fixed the brakes so now it has brakes.Then I got a new battery.The fuel pump is shot,I knew this would be the case.So,now I have the tank off and I cleaned out all the rusty debris from the rotting fuel gauge sender. Here are a few photos of the bike and the inside of the tank befor & after I cleaned it.I have a new ( good used)sender coming .I need to find out what material to make a gasket with for it.Also going to get the pump kit from euroelectrics .I need new fuel lines and then I'm going to look at the injectors.This is all new to me,I work on vintage mostly ,you know ,carbs and points stuff but I've been wrenching for 50 years so I'm not clueless.Any advice would be greatly appreciated.
