1 Best way to get scratches off engine case? Tue Sep 25, 2018 1:01 pm
timz10000
1985 K100
+1. Flat black or crackle will minimize the visible difference in surface finish.nobbylon wrote:I’ve tried to do the same on the cam cover and due to BM’s cast finish all you end up with is a bright spot which looks worse! If it bothers you that much a second hand cover can be had cheaply. Personally I would flatten with emery paper and paint black/crackle black.
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Best way to get scratches off engine case?
Similar topics
