1 Intermittent electrical gremlin Sun Mar 20, 2016 1:03 am
Rockman
I suspect the ignition switch with this one but before I pull it apart I thought I'd ask for other suggestions;
-first time: started and cut out again almost straight away on the Snowys trip. It would crank over but no go. I turned the kill switch off and on, no effect. Then the ignition switch off and on. Started immediately, hasnt done it again since.
-second time: friday this week. Clock missing segments. I stopped, did some stuff, then restarted. Clock came good.
-third time: yesterday and this morning. No clock at all. Went for a ride. Restarted, clock is now all good.
So the question. Is this the ignition switch starting to play up, or a bad connection in the instruments, or something else? Its not serious yet, but is starting to develop.
88K100RT
88K100RT
