1Back to top Go down   Front fog lights assembly Empty Front fog lights assembly Sun May 02, 2010 4:02 pm
Vudis
Hey all, yesterday returning home, I entered huge fog. From that moment on I decided I do need front fog lights. Anyone ever seen them on k100rt? Hard to assemble? Maybe someone already did it?
Front fog lights assembly 20100511
PS Sorry for the dirty bike. Yesterday we had huge rain in here Smile
2Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Sun May 02, 2010 6:26 pm
Alex_GER
Alex_GER
Here's a link to the topic in flyingbrick:
http://www.flyingbrick.de/board/viewtopic.php?f=9&t=2439&hilit=zusatzscheinwerfer
It's in German though, but you can have a look at the pics and follow the links or copy'n'paste the brand names...
Jod alles chlor, liebe Krüße,
euer KLotz
Front fog lights assembly E088Doenerschuss || Portfolio || MPI
http://www.students.uni-mainz.de/alotz/portfolio/
3Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Sun May 02, 2010 7:40 pm
Vudis
Thanx Alex_GER. SOme interesting solutions Smile
4Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Sun May 02, 2010 8:07 pm
To be efficient, fog lights have to be mounted as close as possible from the road.
I don't have fog lights but driving lights and they are mounted on the crash bar.
Here is a picture of the lights mounted on the bike:
Front fog lights assembly K100-l11
Following is the details of the mounting. (I haven't used my engineering software for 3 years. It was a challenge to design it in 3D Very Happy )
When mounting the lights, I recommend to put some rubber washers between the mounting and the light bracket as the vibration may kill the bulbs. (It's almost impossible to get an area without vibrations on the K100)
With this type of bracket, I am pretty confident that I didn't compromise the strength of the crash bars. I had these light for almost a year before finding the best area and the best way to install them. After 3 years, i am still happy with this solution. It's clean and the lights look like it was a factory install.
Note: The hole in my crash bar is slightly eliptical. This permit to rotate the whole mounting to get the best setting of the lights.
There is always a small chance to have water entering the crash bar, and I drilled a 1/8 diameter hole on the bottom of the bars to have the water getting off in case it finds its way in.
This is easy to do and you have 2 solutions to get the round shape of the washers. filing or taking a piece of round stock and drilling a hole equal to the diameter of the crash bar. You then cut a slice on each side of the hole Keeping it at least 6mm (1/4") thick.
What I also forgot to mention on my drawing is that the washers are the main parts of the mounting. The area of pressure on the bars is equal to the whole surface of both washers. Without these washers, this area would be restricted to the contact surface between the spacer & bolts and the crash bar.
Front fog lights assembly Auxila10
You get the idea and I Hope this helps.
Bert
Front fog lights assembly Frog15Front fog lights assembly Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
5Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Sun May 02, 2010 8:12 pm
Vudis
Wow!!!! That's what I really wanted and meant....
Another project, oh no....... Front fog lights assembly Icon_scratch
6Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Mon May 03, 2010 12:55 am
Hey Vudis, here are some simple brackets that attach to your front forks. Have a look here at ebay.
7Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Mon May 03, 2010 3:36 am
phil_mars
What is also interesting on that site is the LED fog lights which seem damn cheap and should not be susceptible to vibration.
8Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Mon May 03, 2010 10:32 am
phil_mars wrote:What is also interesting on that site is the LED fog lights which seem damn cheap and should not be susceptible to vibration.
Last week I was reading articles on LED light as I was considering them for my house.
To sum up my reading, unless you buy a high quality product, you are waisting your money.
The "made in China" are cheap, but their lifespan is far from what they advertise. One of the other complain is that they are losing their brightness over time.
Laptop manufacturers had already tried to replace the LCD back light (cold cathode fluorescent lamp) with LEDs. It was obviously a problem as everybody went back to fluorescent lights.
The latest technology is OLED. I believe that one of our member was doing research on Nanobiotechnology (Alex_GER?) and he can tell us more about it.
Last fall I went to a trade show and saw the new GE commercial line of products using OLED technology. I was very impressed by the brightness, but this "new" technology is still way too expensive for my wallet Sad
Here is the future of OLED lightning:
9Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Mon May 03, 2010 10:54 am
phil_mars
Currently the room I am in is lit (dimly I grant you) by 2W! of led lighting.
If I wanted to spend $50 per globe I could have upped that to 6W (3ea) and theoretically equivalent to 100w (total) Halogen globes.
LED monitors are already appearing for the same price as LCD ones but I am interested to see where the LED driving lights are going as they are starting to make an appearance and I would never have thought they would have the brilliance and distance qualities demanded . It would seem thay may surpass HID technology.
As usual time will tell.
Phil
10Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Fri Mar 11, 2011 3:58 pm
Oldgoat
Oldgoat
Hey Bert can you tell me the model and wattage draw of the lights you are using? I really like the stock appearance of your setup!
OG
11Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Fri Mar 11, 2011 9:05 pm
These one are very cheap (Understand Made in China). They are H3 and not very good at night. I installed them as driving lights for day time. They are very efficient for this purpose.
12Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Sat Mar 12, 2011 1:07 am
Check these beauties! I used to sell them, they are not inexpensive, but are incredibly versatile and everything (even the globes) are covered under a full lifetime warranty. They clamp to the fork legs (old style) or are mounted on the upper caliper bolt. Very slick and effective.
http://www.motolight.com/page/401585602
13Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Sat Mar 12, 2011 6:40 am
walfish
walfish
Hey TWB, those lamps seem to be the answer, looking at your web link I see there are no dealers here in the UK, but I'm sure someone will have them.
14Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Sat Mar 12, 2011 12:23 pm
Re-Psycle has this set of bracket for sale on Ebay (Brackets only for $100 with shipping affraid ). See there
You get the idea... An afternoon drilling, filing and hammering could produce the same result for about $10 Very Happy
I personally don't like the idea of attaching the lights on the fairing. In case of a mild crash the mirrors will pop out and the fairing will sustain minimal damages. These brackets will crush the side of the fairing.
Front fog lights assembly Bracke10
Front fog lights assembly Bracke11
Front fog lights assembly Bracke12
Front fog lights assembly Bracke13
15Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Sat Mar 12, 2011 2:46 pm
BIG D
BIG D
Cool
USED AS WELL Shocked as you say Bert a little workshop time could produce a set why, you even have your own template for the mounting with the original supports.
BIG D
16Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Mon Mar 21, 2011 8:18 am
If you are planning to mount your driving/fog lights on the crash bar, do not hard wire them right to the headlight or relay box. Install a plug near the crash bar. It will permit to remove the crash bar without having to remove the light.
Here is where I installed the plug.
Front fog lights assembly Dsc_1612
Here is another tip for the RT owners:
In order to remove the lower fairing, you have to remove the crash bars. I modified my lower and in stead of having a hole I cut a slot where the bars bolt on the frame. Now I just have to tilt the lower to remove it. Much easier if you have a problem on the side of the road
Front fog lights assembly Dsc_1613
17Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Mon Mar 21, 2011 8:55 am
If you are using a nice, two wire quick-disconnect SAE connector as in CF's photos, no worries, no need to be concerned. But if you intend to use a single wire to positive and then earth (ground) a wire to the engine protectors be sure to also connect short leads to the chassis or engine as the engine protectors are rubber mounted and therefore 'isolated'.
This is Electricity 101, but a gentle reminder can help sometimes.
18Back to top Go down   Front fog lights assembly Empty Re: Front fog lights assembly Mon Mar 21, 2011 7:40 pm
BIG D
BIG D
Crazy Frog wrote:Here is another tip for the RT owners:
Cool
Thats such a good idea Bert the cut out for the crash bars, now where is my fret saw got to copy that.
BIG D
