1Back to top Go down   volt gauge Empty volt gauge Wed Mar 02, 2016 1:42 am
Viper357
Viper357
Hey everyone
Just another silly question from a newbie.................................
How do I wire up a VDO ( or other makers ) Voltmeter gauge? The OEM BMW ones are hard to find and insanely expensive here in Oz
I am electrically challenged so please be kind  lol!
gary
1985 BMW K100RS
2Back to top Go down   volt gauge Empty Re: volt gauge Wed Mar 02, 2016 2:38 am
Gary in this section under how to's you will find a thread called add gauges its done my Marky boy on his 1100 and he used VDO gauges
3Back to top Go down   volt gauge Empty Re: volt gauge Wed Mar 02, 2016 5:26 am
Viper357
Viper357
Thanks guys  Very Happy
I still cant get over how everyone helps out - its really cool
cheers fellow brickers volt gauge 22936
1985 BMW K100RS
4Back to top Go down   volt gauge Empty Re: volt gauge Wed Mar 02, 2016 7:18 am
volt gauge Vdo_vo10
5Back to top Go down   volt gauge Empty Re: volt gauge Wed Mar 02, 2016 1:16 pm
Viper,
Be careful with the source of +12 volts.
When I fitted a voltmeter to my solo RS, I picked up a 12 volt supply from a point somewhere inside the relay box (I can't remember exactly where), and got a reading of only 11.2 volts. Ah, I thought, a duff battery, so I bought a new battery an guess what? Still 11.2 volts!  Embarassed
So, you need to find a fused point near the battery without any voltage drop.
6Back to top Go down   volt gauge Empty Re: volt gauge Wed Mar 02, 2016 6:21 pm
... and switched so it comes on with the ignition. Best solution is to wire the gauge through a small 12Volt normally open relay. connect one side of the contacts directly to the battery +ve, the other side to the +ve input of the meter. Connect one side of the coil to ground and the other side of the coil to a source of switched +12V. The remaining side of the meter gets grounded.
7Back to top Go down   volt gauge Empty Re: volt gauge Wed Mar 02, 2016 6:46 pm
Just to add my 1.5C; I did something similar to Duck except that where he's used the black-green wire, I picked up the green wire off the back of the ignition switch. No voltage drop to worry about as it's switched directly from the battery.
8Back to top Go down   volt gauge Empty Re: volt gauge Wed Mar 02, 2016 7:13 pm
I tap into the gauges connector for the separate factory fuel and temp gauges.  Seems logical to me.
9Back to top Go down   volt gauge Empty Re: volt gauge Sat Mar 05, 2016 6:24 am
Viper357
Viper357
Thanks guys  volt gauge 112350
Even I should be able to wire this up    lol!
Keep tuned watch this space................................
1985 BMW K100RS
10Back to top Go down   volt gauge Empty Re: volt gauge Sat Mar 05, 2016 5:26 pm
ReneZ
ReneZ
I'm with Duck; there's a special connector for additional instruments under the tank, with a switched power, ground and switched light contact. All you need :-)
Rene
BMW K100 - 1985 (0030029) Scotland volt gauge Rain
11Back to top Go down   volt gauge Empty Re: volt gauge Sun Mar 13, 2016 4:44 am
Viper357
Viper357
Thanks everyone  volt gauge 112350
will be a project over the easter break here in Oz .................
Gary
1985 BMW K100RS
12Back to top Go down   volt gauge Empty Re: volt gauge Wed Mar 22, 2017 5:03 am
soso
soso
Hello,
Please can you help me I buy volt gauge BMW MotoMeter and I need scheme how is corectly conect to my bike BMW K100 rs
Thank you
It is better to be young, rich, beautiful and intelligent than the old, poor, ugly and stupid. by Alan Ford
https://www.youtube.com/watch?v=_eyhrS3ODTw
13Back to top Go down   volt gauge Empty Re: volt gauge Wed Mar 22, 2017 8:13 am
Connect it between earth (ground) and a switched 12v source like the grey/blue or green wire at the plug for the ignition switch.
14Back to top Go down   volt gauge Empty Re: volt gauge Thu Mar 23, 2017 8:52 am
soso
soso
Thank you for answere when I instaled them I put picture here.
15Back to top Go down   volt gauge Empty Re: volt gauge Fri Mar 31, 2017 8:04 am
soso
soso
RicK G wrote:Connect it between earth (ground) and a switched 12v source like the grey/blue or green wire at the plug for the ignition switch.
I do it like you say to me and work fine, I connect between (ground and green wire for ignition switch.volt gauge Dsc_0314
volt gauge Dsc_0314
volt gauge Dsc_0315
16Back to top Go down   volt gauge Empty Re: volt gauge Fri Mar 31, 2017 9:21 am
Another satisfied customer cheers
17Back to top Go down   volt gauge Empty Re: volt gauge Fri Mar 31, 2017 10:29 am
soso
soso
No problem when you come in Croatia  volt gauge 212902
18Back to top Go down   volt gauge Empty Re: volt gauge Fri Mar 31, 2017 11:17 am
BobT
BobT
soso wrote:No problem when you come in Croatia  volt gauge 212902
Never mind that are you coming to France in September with the Irish guys?
19Back to top Go down   volt gauge Empty Re: volt gauge Fri Mar 31, 2017 12:34 pm
soso
soso
What hapening in France in september, I dont now anybody of Irish guys????
I am sorry but I dont understand.
20Back to top Go down   volt gauge Empty Re: volt gauge Fri Mar 31, 2017 1:08 pm
BobT
BobT
