1Back to top Go down   New shock from Aliexpress Empty New shock from Aliexpress Mon Dec 09, 2019 11:38 am
nino
Hello all,
I tried new shock from Aliexpress. All together 72 euros, shipment more expencive than shock.
Its 360 mm from eye to eye, spring 12 mm, shaft 14 mm, 800 lbs capacity.
I need a litle modification and drilled lower and upper eye from 10 mm originaly to 12 mm needed for K 100.
Its on the bike, I drive it few days now. Impressions: little stiff but bike got much better steering. Shock absorbs very well.
Here is a link
https://www.aliexpress.com/item/32946165352.html?spm=a2g0o.productlist.0.0.33cb6eb2dEhO2K&algo_pvid=10e55dc5-18b3-41b4-9aca-7aac8ca71e1a&algo_expid=10e55dc5-18b3-41b4-9aca-7aac8ca71e1a-2&btsid=051d09eb-28ab-4fc3-b304-50f1cece3cdc&ws_ab_test=searchweb0_0,searchweb201602_10,searchweb201603_53
2Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Mon Dec 09, 2019 12:49 pm
brickrider2
brickrider2
That price is shocking!  Shocked  Do let us know how it performs.
1996 K1100LT
3Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Mon Dec 09, 2019 1:09 pm
nino
So far so good. There is a possibility to order 325 mm shock with 10 mm spring which is lower and softer but Im happy with stronger version.
I ll report any problem.
4Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Mon Dec 09, 2019 2:39 pm
nino wrote:Hello all,
Its 360 mm from eye to eye, spring 12 mm, shaft 14 mm, 800 lbs capacity. . . .
What is the outside diameter of the spring, nino?
5Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Mon Dec 09, 2019 2:50 pm
nino
Outer diameter 76 mm compared to 68 of original Koni shock. It doesnt disturb right hand panier.
6Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Mon Dec 09, 2019 3:31 pm
The longer one will be for Paralever, the shorter one for Monolever.....good price too.
7Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Mon Dec 09, 2019 6:27 pm
A few years ago, a friend of mine bought such a cheap asian shock for his BMW Monolever. He was very happy to show us its good bargain to the annual meeting to persuade us it was a very good idea to save  50% on the price of a shock.
He never attended it.
Ths shock broke when he was riding.
He's still alive, yet. Doctors saved 50% of its brain.
Good bargain.
8Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Mon Dec 09, 2019 7:02 pm
JR_K100RS
JR_K100RS
100% with you jbt , buy it cheap buy it twice ( or three times ) , no such thing as good quality cheap shocks , they are either good or cheap , no way I'd trust this on my bike . My shock story is : 1st replacement was a White Power , expensive and really poor quality , next : fat body Koni , good but way too hard , then an Ikon chrome body ( don't remember the model ) not too bad surprisingly : next another Icon ( searching for something better ) this was the alloy body unit , garbage . Finally bit the bullet and got the shock that I should have bought 25 years earlier instead of the crap WP , an OHLIN , if I listened to my own advice I'd have saved years of screwing around and lots of cash
may the flaming begin
John Re Melbourne Australia
9Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Tue Dec 10, 2019 1:39 am
volador
volador
You guys are raining on Nino's damper thread. Keep us posted on performance Dovidenja
Stock OE Damper length
K100 4V, K1100 (paralever)- 390mm 15.375"
K75, K100 2V (monolever)- 360mm 14.2"
For lowering K75- Progressive Suspensions #412-4016B  13.2"
YSS Suspensions offers many lengths in something like a Z-366 TR
http://www.yssusa.com/series-z.html
10Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Tue Dec 10, 2019 4:36 am
nino
I have few chinese items on my old K.
Handlebar risers 20 US dolars - perform as it should
Intank fuel pump  22 USD - 1 year in place perform better than old original
Now shock absorber - craftmanship looks very well, drive feeling rock solid. Will it break and kill me? I dont believe it looks overconstructed
Cross your fingers for me
11Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Tue Dec 10, 2019 6:47 am
Nino you need to get a Chinese rear master cylinder $15.00 Au. And I've happily been running a Chinese OEM copy fuel pump since July 2017. And I'm in the process of upgrading my 4.5" Chinese Fodsports GPS now 4 years old and can't get map updates as it runs on Windows CE 6.0 easily. Upgrading to the new 5" Fodsports running Android. I run RAD rebuilt OEM shocks which are upgraded from OE.
12Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Thu Dec 19, 2019 4:15 am
nino
Hello Martin, do you have any reccomendation for rear brake cylinder? Link maybe?
13Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Thu Dec 19, 2019 5:08 am
Woodie
Woodie
This looks like the one a bunch of us have been using.  Looks like you can get powder coated in black which saves you the time of painting it black to match the original.
New shock from Aliexpress Logo2111
1985 K100RT  52667
1990 K75RT 6018570 (project)
14Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Thu Dec 19, 2019 5:10 am
tinyspuds
tinyspuds
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F323868836265
I’ve been using one like this about 5k miles. Very pleased. NB. You need the one with slotted mounting holes.
I also got a barbed reducer to splice the hoses and reuse oem reservoir.
15Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Thu Dec 19, 2019 5:34 am
nino
How did you connect to foot pedal?
16Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Thu Dec 19, 2019 5:36 am
tinyspuds
tinyspuds
Nino There are a few threads on here called chinese master cylinder or similar and a few different ways to do it. Here’s mine.
https://www.k100-forum.com/t15108-replacing-rear-master-cylinder-with-a-chineese-one#176855
In order to get the correct amount of travel on the push rod the double locknut was a bad idea. It needed too long a pushrod which then ended up binding the brake. I now use a single nut, the oem adjustor bolt, and a depression drilled in the push rod end.
It was super easy, but you must get the push rod length right, and have freeplay at the pedal as per the manual.
17Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Thu Dec 19, 2019 6:28 am
Do not use the Chinese supplied reservoir hose, it is not rated for brake fluid. I was doing a check over before a long ride, I saw that the supply hose was moist on the surface. As I gently wiped it the supply hose disintegrated dumping fluid over the floor. If it had done so while I was on my ride,it would have dumped the fluid over my back tyre, with dire consequences.
Regards Martin.New shock from Aliexpress Reserv12
New shock from Aliexpress Reserv13
Regards Martin
18Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Thu Dec 19, 2019 7:06 am
tinyspuds
tinyspuds
Good catch Martin Thanks
19Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Thu Dec 19, 2019 9:57 am
nino
Absolutely clear. Thanks.
Few words about new chinese shock. What I like most is much improved steering. By the way in front fork are Wurth Progressive spring. With New shock on the rear bike is much better in every way. No shimmie at 80 kmh and faster in curves.
Its only ten days experience but I am very content.
Best regards
20Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Thu Dec 19, 2019 2:31 pm
21Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Thu Dec 19, 2019 2:47 pm
Reply #32 of this thread starts a sequence of posts that show how I put the ChiCom master cylinder on my K75RT. Since then I have put them on three more bikes.  That K75T now has well over 20,000 totally trouble free miles on the master cylinder shown in the thread.
BTW, The modification of the ChiCom cylinder is a lot easier than trying to clean up the bore of the crap Magura master cylinder that came with the bike.
http://www.motobrick.com/index.php/topic,9364.25.html
Boy, I wish I knew about the black powder coat sooner.
22Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Thu Dec 19, 2019 3:20 pm
Because of the location of the rear master cylinder it is subjected to a lot of water spray and crap, as well as salt in countries where they salt roads in winter. Even though I am running a Chicom master cylinder I still have my OEM one in still great condition. In order to keep the cylinder from corroding under the boot, I pack the area under the boot with heavy silicon grease. It stops the ingress of water and crap and prolongs the life of the boot. Even in Qld I've seen rear master cylinders corroded, some with split boots and some with intact boots. Checking the condition of your boot should be part of your service procedures.
23Back to top Go down   New shock from Aliexpress Empty Re: New shock from Aliexpress Tue Apr 14, 2020 11:42 pm
lion1453
lion1453
forget the shit its very poor :S
