1Back to top Go down   Rear master cylinder alternative Empty Rear master cylinder alternative Wed May 20, 2015 10:04 pm
brianpen
brianpen
Rather than rebuilding my rear master cylinder on my 87 K100LT, I figure a newer replacement might be a better bet. When scanning ebay it appears many units from newer BMW's appear nearly identical. The R1150RT in particular. The pricing is much more reasonable. Has anyone swapped one of these or similar units? As it is a rear brake, I suppose optimum braking isn't crucial, after all I have been living with a wimpy K100 version for some time now.
2Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Thu May 21, 2015 1:30 am
The manner in which the piston is pulled and pressed by the brake pedal is different from other Beemers, even some other model Ks. I think you'll find that if you want original equipment operation you'll need an OEM-type master cylinder.
3Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Fri May 22, 2015 7:16 am
TWB - I think BrianPen is right. The R1150RT rear master cylinder does appear to be the same one as fitted to the K100; my caveat is that the hole spacings may be different. This listing distinctly shows that it's a push M/C in similar fashion to the K100:
http://www.ebay.co.uk/itm/04-2004-BMW-R1150-R-1150-RT-ABS-R1150RT-REAR-MASTER-CYLINDER-BRAKE-8585-/351295869872?hash=item51cadd93b0
Interestingly, there's no rubber buffer between the actuating rod and the M/C piston.
This one shows the same bellows fitting as we have:
http://www.ebay.co.uk/itm/BMW-R1150RT-2004-Twin-spark-51-547-miles-rear-brake-master-cylinder-/161682225730?pt=LH_DefaultDomain_3&hash=item25a502fa42
BrianPen: like you, I hated the feel of the rear master cylinder. I threw away that stoopid rubber buffer and replaced it with a home-made solid stainless steel one. IMHO instant improvement in feedback and braking.
4Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Fri May 22, 2015 8:34 am
I could be missing something here, but aren't the mounting bosses on the R1150 M/C on the bottom of the unit whereas on the K bike master cylinders they are on the top.  How can they be interchangeable?
5Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Fri May 22, 2015 9:13 am
I have an R1150RT in my garage too. The rear MC from that wouldn't work on a K100/K1100 unless you replaced the footpeg mounts and brake pedal with something custom.
6Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Fri May 22, 2015 12:49 pm
Ah - that bit of information isn't exactly visible in pictures!
7Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Fri May 22, 2015 2:06 pm
A coupla months ago I looked at as many options I could for my project bike. In the end I ordered a new 13mm rear M/C. There wasn't gunna be an easy answer unless I went the (wicked kewl) BSK Speedworks rearset way, or other. I opted for standard peg plates and stock position....for now.
8Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Wed Jan 30, 2019 7:40 am
jdaley
jdaley
Can you give me more details I am new to K100's please
John Daley
Bendigo, Asutralia
9Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Wed Jan 30, 2019 8:18 am
I've been running a Chinese rear master cylinder purchased of Ali express for $13.33 AU. Easy conversion some models may require a new hose.http://www.motobrick.com/index.php/topic,9364.msg90596.html#msg90596
10Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Wed Jan 30, 2019 11:04 am
I, too, am running those Chinese master cylinders on two of my bikes and have a combined 20,000+ trouble-free miles on them.  Probably the best $12 I have ever spent on my bikes.
IMNSHO, when it comes to rear master cylinders, f*ck BMW.
11Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Wed Jan 30, 2019 7:47 pm
jdaley
jdaley
I am having trouble finding the Chinese part, can you help me please?
John Daley
Bendigo, Asutralia
13Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Sun Jan 26, 2020 11:13 pm
Packo
Packo
Ordered 12 Jan 20 expecting a "long" wait.
Delivered 24 Jan 20
Gotta be happy with that!!!
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
14Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Mon Jan 27, 2020 3:19 pm
Just a warning for those contemplating fitting a Chinese master cylinder. DO NOT use the supplied hose between the reservoir and the master cylinder. It is not rated for brake fluid and it will fail eventually possibly dumping brake fluid over the rear tyre. The cylinder itself is fine and I believe it has better feel than the OEM.
15Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Mon Jan 27, 2020 8:52 pm
nods
nods
Thanks a lot for the hot tip Martin.  Chinese special M/C on the way!
Chassis number0025951
Vehicle code0504
ModelK 100 RT 84 (0504 ( 0505 )
Body typeK 100 RT 84 (0504
Production date1985 / 01
Engine0514)
Transmission
Steering
CatalyzerNONE
16Back to top Go down   Rear master cylinder alternative Empty Re: Rear master cylinder alternative Tue Apr 14, 2020 11:43 pm
lion1453
lion1453
from s1000rr fits perfect you can buy cheap
