Number of posts : 11701
I think rick and I have the same device mark
heres a pic so you might be able to chase up the numbers
note mine has 9mm barbs ....so 8mm line just fits on it ok
I mounted mine up like this using nutserts to the aluminium frame ..and some uchanel aluminium and 4mm bolts washers etc all stainless
this is shown on the 2 core radiator for clarity ...but will be retro fitted again to the 3 core radiator once the fuel mixture and running is sorted out a little more ...(think my orginal afm is faulty after a swap over ...measurements to come )
but the result is a much cooler tank .....it wont solve the heat around the inner thighs altogether ...that's just a constant blast from the airflow from the radiator ...but will go a long way to help
more details of some other mods to air cooling into the under tank area are about to happen
hope that helps
