1Back to top Go down   Clutch Cable adjustment 86 K75 Empty Clutch Cable adjustment 86 K75 Tue Dec 15, 2015 12:13 pm
Sunnyk75
Sunnyk75
hi expert brickers
I am on another clutch cable after 3 previous ones. I researched and found out I contributed to its demise by not inspecting and lubing the barrel. Can someone explain how I can adjust the cable so that the tension when operated goes back to normal? I know it should not be this stiff when I pull. Is it as simple as removing and cleaning the clutch/side stand return arm?
Many thanks
Sunny
2Back to top Go down   Clutch Cable adjustment 86 K75 Empty Re: Clutch Cable adjustment 86 K75 Tue Dec 15, 2015 2:07 pm
Yeah I had that problem......decided to replace it and found it had frayed and couldn't return to the correct position.
Since you have new cables maybe not a problem, provided you are lubing the handlebar lever nipple so it can rotate in the lever and not pull the individual strands out of the nipple. Also can cause it to stick in the handlebar part of the mechanism. Been there.
Routing??
3Back to top Go down   Clutch Cable adjustment 86 K75 Empty Re: Clutch Cable adjustment 86 K75 Tue Dec 15, 2015 11:44 pm
A Search reveals...everything you wanted to know about clutch cables but were afraid to ask!
The Search function is your friend. It is amazing the other stuff you learn when looking for something specific.
Last edited by blaKey on Tue Dec 15, 2015 11:45 pm; edited 1 time in total (Reason for editing : nuthin' in particular...)
4Back to top Go down   Clutch Cable adjustment 86 K75 Empty Re: Clutch Cable adjustment 86 K75 Wed Dec 16, 2015 5:16 am
Chocolate
Chocolate
Hello Sunny!
Hope you adjusted the clutch cable correct.
75+-1 mm!
You will find how to in the Manuel PDF in English for download her
I only have a hand made German version
Clutch Cable adjustment 86 K75 Kupplungeinstellen%20
5Back to top Go down   Clutch Cable adjustment 86 K75 Empty Re: Clutch Cable adjustment 86 K75 Wed Dec 16, 2015 6:40 am
Chris Harris youtube video...all you need and simple...
Clutch Cable adjustment 86 K75 Ir-log1188....May contain nuts!Clutch Cable adjustment 86 K75 Ir-log11
K75RTP - 1994
6Back to top Go down   Clutch Cable adjustment 86 K75 Empty Re: Clutch Cable adjustment 86 K75 Wed Dec 16, 2015 7:20 am
Sunnyk75 wrote:hi expert brickers
Many thanks
Sunny
When it goes stiff its usually a sign that the sheath has worn out. If you have BMW cables they should not be lubed as it destroys the Teflon sheathing. The Featherlight brand cables require a bit of light lube now and again as per their instructions.
If its always been stiff its probably due to incorrect routing.
The nipple at the handlebar lever should be lubed to prevent cable stress and fraying .
 Clutch Cable adjustment 86 K75 Austra12    Fuel:  95 Octane
7Back to top Go down   Clutch Cable adjustment 86 K75 Empty Re: Clutch Cable adjustment 86 K75 Wed Dec 16, 2015 9:36 am
Chocolate
Chocolate
88KE wrote:Chris Harris youtube video...all you need and simple...
I like Chris Harry's Video and learned a lot.
In this case BMW Manual writs somehow different.
To adjust the length to 75mm you will have to disconnect the clutch cable first from the withdrawal arm! Then measure.
I just did it this morning for both bikes, so that the clutch last a bit longer, hopefully:-)
Clutch Cable adjustment 86 K75 Image18
Clutch Cable adjustment 86 K75 Image19
8Back to top Go down   Clutch Cable adjustment 86 K75 Empty Re: Clutch Cable adjustment 86 K75 Wed Dec 16, 2015 10:18 am
That's the cable adjustment but the clutch operating lever should be adjusted as well (behind gearbox r/h side)
The Haynes manual describes the cable adjustment a little differently without removing the cable from the clutch operating lever and I think that's a better way.
I always adjust the operating lever first and then the cable.
But I doubt the cable adjustment would cause the stiffness reported by the OP. If the clutch lever has become hard to pull in its highly likely the cable is worn out.
9Back to top Go down   Clutch Cable adjustment 86 K75 Empty Re: Clutch Cable adjustment 86 K75 Wed Dec 16, 2015 11:43 am
I have found that when the cable length is adjusted to 75mm on my K75's the arm touches the muffler and makes an obnoxious clanking, especially when running down the road at cruising speed.
I check for this by pulling in the clutch lever all the way and then letting it snap out.  If you hear a clank as the arm hits the muffler you need to take up a little bit of the cable length.  When you've done that you will need to readjust the pushrod bolt to get the correct lever freeplay.
10Back to top Go down   Clutch Cable adjustment 86 K75 Empty Re: Clutch Cable adjustment 86 K75 Wed Dec 16, 2015 5:35 pm
Yes Point-Seven- five, there's a theoretical figure   Clutch Cable adjustment 86 K75 78846  (for the pedantic amongst us)
 and a practical figure for those who have a bit of common sense.  idea2
11Back to top Go down   Clutch Cable adjustment 86 K75 Empty Re: Clutch Cable adjustment 86 K75 Thu Dec 17, 2015 1:06 pm
Cheers, Paul.  For the pedantic amongst us, the optimum dimension is 73.8731mm.  I suspect those lazy engineers at Motorad just rounded off to 75.
jim
12Back to top Go down   Clutch Cable adjustment 86 K75 Empty Re: Clutch Cable adjustment 86 K75 Tue May 17, 2016 11:09 pm
1990k75
1990k75
Point-Seven-five wrote:I have found that when the cable length is adjusted to 75mm on my K75's the arm touches the muffler and makes an obnoxious clanking, especially when running down the road at cruising speed.
Ha! That 'clanking' is exactly why I have been searching these old threads  Smile
Does the muffler have to come off to adjust the pushrod bolt? Not looking forward to that...
Any other consequences if I leave it to 'clank'?
And hello to you Jim Clutch Cable adjustment 86 K75 22936
Past bikes - Yamaha YL-1, Honda XL-125, 1967 BSA 650 Lightning
Current - 1990 K75RT (in drydock) & 1995 K75RT VIN # WB1056503S0372669
            - 2011 Suzuki V-Strom 650
            - 2011 Yamaha XT250
Who sez I'm too old to ride?
13Back to top Go down   Clutch Cable adjustment 86 K75 Empty Re: Clutch Cable adjustment 86 K75 Tue May 17, 2016 11:48 pm
I adjusted the gap so it doesn't quite touch the muffler and have had no problems.
Its a common complaint.
