1 Clutch 86 K100rs Sun May 01, 2016 8:47 pm
Flip2
hi again, after finally getting the k100rs to start after replacing the temperature switch i was shocked to find that prior to my first test ride i lost my shifting , as in when i let off the clutch it jumped into first gear,(same with second) and i had to use the kill switch on that first ride as engaging the clutch wasn't enough to reduce all the power to the real wheel, i replaced the clutch and clutch cable , when i serviced the splines and replaced the rear main seal. i put on a few hundred miles after that work and then the bike basically sat for the last year,
with the engine off it will roll in neutral and it will go back into neutral.
anyhow so far i have adjusted the clutch cable and inspected the bearings and spring under the clutch boot arm and didn't see anything out of the ordinary, i adjusted the detached clutch cable (venhill) to 75mm and reattached the cable to the arm, this allowed me to slightly raise the arm up with my hand , like when pulling on the clutch lever, but after screwing in the adjustment screw thru the boot arm until it stops and then tightening the lock nut i noticed then that i could not push up on the arm, with two hands, and the clutch lever is tight,
should the arm be able to be pushed up after being adjusted? any ideas in general?
discouraged
discouraged
