1 K75S Throttle position sensor Fri Sep 18, 2015 9:32 pm
Altorr
Hi, my recently purchased K75 backfires and quite loudly. I am concerned firstly for possible exhaust damage it may cause so I have stopped riding it till I can sort it.
I sourced a workshop CD manual which states adjustment needs a diagnostic scan tool which I don't have.
I researched the issue on forums etc and came up with solutions of TPS adjustment via multimeter use and listening for a click upon throttle movement down at the TPS.
I have checked plugs, valve clearances.
The bike is a 1992 model with 72000 kms with an excellent service history. The previous owner told me he learned to ride with throttle adjustments to avoid it. I imagine there is a way to eliminate these loud bangs. The occasional pop is not an issue.
I have simply adjusted the TPS so that now, as the throttle leaves the closed position I hear a click and as it returns it clicks too.
My question is can I cause any detrimental effect to the engine from adjusting this TPS without using the correct technique/tools?
Thanks Alf
Thanks Alf
