1Back to top Go down   K75RT tank grummets Empty K75RT tank grummets Sun Sep 13, 2015 12:07 pm
jkh
jkh
Me and my K75RT 93 Are om the Ferry on the way home after a fantastic wrenching and driving weekend with a friend and his R1100R. We did almost everything that is beyond normal maintenance. All splines lubed, brakefluid and coolant changed. All electrical connections greased with dielectric grease etc. She runs like never beforw and my sticking clutch is gone thanks to tranny input spline lube with guard dog moly. Gar shifting is like cutting hot butter.
Ny only problem was getting the tank off and on. Its like I couldn't get the rear tank pegs down far enough to get the clips out and in. Here on the Ferry it occurs to me that maybe the rubber grommets on the rear tank pegs should be mountet on the frame eyes rater the all the way up on the tank rear pegs. Can someone in here supply a picture of how the grommets and clips is mountet in the eyes on the frame?
2Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Sun Sep 13, 2015 12:28 pm
JGT
JGT
Which ever way they should be fitted, a smear of red rubber grease works wonders. John
1992 K75
3Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Sun Sep 13, 2015 2:11 pm
DeRodster
DeRodster
I don't know if they are the same as the K1100, but I have had difficulty with one of mine.
the right hand side sit's in easy every time, but the left just wont.
I've tried greasing it but it just gets pushed thru the bottom.
So now I leave it on the peg, make sure it's well greased and that seems to work fine.
Then the clips just go  on easy
Hope that helps
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
4Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Sun Sep 13, 2015 3:30 pm
jkh
jkh
The reason i asked this question is that I needed to have my friend to put all of his weight (+90 kg) on the tank to get the  rear pegs of the tank far enough down  so it was possible slide in the clips from the rear. I wonder what less weighty wrenchers do?
My guess is that i either have the wrong grommets or they are not seatet corretly. I am a bit reluctant to take the clips of again since i cannot put them on just a single person. So could someone please post a picture or a drawing of how the grommets and clips look like on their brick?
'93 K75RT - Previous bikes: '53 AJS Matchless, a lot of 70'ties Honda sohc/4's and some MZ's
5Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Sun Sep 13, 2015 5:11 pm
Motorbike Mike
Motorbike Mike
I have quite a few tanks knocking about and a couple of them are the same, though not as bad as yours.
I wonder if they are a little twisted-perhaps when they were made?
6Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Mon Sep 14, 2015 1:20 am
jkh
jkh
Its more like if the pegs are to short or the grommets are to thick. The pegs line up fine with the corresponding eyes in the frame. It's just that the tank need to be pressed down with +80 kg to compress the grommets enough to be able to put on the clips.
Maybe PO have used some other rubber he had laying around as grommets and they are of the wrong shape or thickness. I have looked at realoem.com partsdrawing but the parts are drawn to small to be able to see how the grommets look like and there are no dimensions on the grommet.
Thats why a picture or a drawing could help me.
7Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Mon Sep 14, 2015 1:32 am
No problem getting the clips on my K75, but there is no way I can get them on my K100.  In a season of riding I have discerned no negative effect from not having the clips installed and if anything it makes moving the tank to access things like the coolant filler much less stressful.
I am so confident that they are not needed that I have not reinstalled the clips on the K75 after my last undertank foray.  With the seat down, I can't see how the tank can move more than a couple millimeters anyway.
As to why the clips won't go in, all it takes is a brief glance at the mass of wiring, insulation, air dams, etc. under the tank on my bikes to give me a good clue as to the source of the problem.
8Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Mon Sep 14, 2015 2:11 am
Never had grommets or clips on mine. Hasn't been a problem. Have always had to jiggle the tank around to get it off the rear mounts so I can't see it coming off too easily with the seat on. A severe accident may be a different story tho.
Try cutting the grommets down a little and/or ream out the centre to make the posts fit easier.
K75RT tank grummets TAA55167
 K75RT tank grummets Austra12    Fuel:  95 Octane
9Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Mon Sep 14, 2015 6:43 am
To make life a bit easier, soak the grommet in hot water for a minute or two, then smear Vaseline (or similar) over it and push it on.
The photo above shows it upside down as to how it is installed. Round edge down, squared edge up.
I hope this helps.
Oh, by the way, as previously mentioned, the clips can be a pain in the butt to attach.
I have the grommets but no clips.
10Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Mon Sep 14, 2015 7:42 am
K75RT tank grummets <a href=K75RT tank grummets Gromme10
11Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Mon Sep 14, 2015 8:03 am
Onya Kaptain!
12Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Tue Sep 15, 2015 6:06 am
Howard64180
Howard64180
From your description, I think you're on the right track in your first post.  Take the grommets off the tank posts and push them into the frame holes, with the wider part at the top.
13Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Wed Sep 16, 2015 2:35 am
jkh
jkh
Howard64180 wrote:From your description, I think you're on the right track in your first post.  Take the grommets off the tank posts and push them into the frame holes, with the wider part at the top.
I think that the grommets is mountet the wrong way - like upside down. When i took them of they stayed attached on the pegs. I suppose they shuold stay seated in the eyes on the frame.
I will try to take the clips out this afternoon when i come home from work because i have to cover he CO adjuster hole in the upper airbox with tape. I hope I will be able to reattach the clips after this.
Thanks for all the replies
/Jens
14Back to top Go down   K75RT tank grummets Empty Re: K75RT tank grummets Wed Sep 16, 2015 9:50 am
jkh
jkh
I had the tank of this afternoon. They where not upside down but they were like melted to the tank pegs. I loosened them and put them into the frame eyes, lubed the grommets where the pegs go through and then everything vent together easy.
