Be made
Be made
As per the thread title, was wondering if there is any difference between oil filters on a k1200 as opposed to k100
reason being I have several new filters for the K100 I am about to sell but if they fit the new bike I would keep them
many thanks to all who reply
regards
keith
AFAIK they are the same.
kioolt
kioolt
It fits several models of bikes for several years.
11421460845
Oil filter
Supersedes:
11421460832 (11/14/1983 — 05/25/1984), Exchangeable retrospectively11421460858 (08/01/1983 — 06/29/1984), Exchangeable retrospectively11421460833 (08/01/1983 — 03/30/1984)
Part 11421460845 was found on the following vehicles:
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
Yep, Bricks & Oilheads (1100 & 1150) take the exact, same oil filter,
11 42 1 460 845.
In kit form it's 11 00 2 300 053 and you get the filter, engine sump o-ring, drain plug gasket and two sub-10mm crush washers for fork oil refill under the fork top plugs - a service kit.
As an aside, for Oilheads it's 11 00 1 341 616 but you get pertinent crush washers for engine oil, gearbox drain/fill and final drive drain/fill.
Be made
Be made
Beautiful . . .just awesome responses guys, Thank you all so much. Again . . .  why I love this forum . .  so much!
Your all so great!
Difference in oilfilter between '98k1200 and standard k100? 112350 Difference in oilfilter between '98k1200 and standard k100? 112350 Difference in oilfilter between '98k1200 and standard k100? 112350 Difference in oilfilter between '98k1200 and standard k100? 112350 Difference in oilfilter between '98k1200 and standard k100? 112350 🆒 🆒 🆒 Difference in oilfilter between '98k1200 and standard k100? 502531 Difference in oilfilter between '98k1200 and standard k100? 502531 Difference in oilfilter between '98k1200 and standard k100? 502531 Big thumb Big thumb Big thumb
