1 How necessary is it to install the nut on the water pump impeller? Wed Jul 01, 2015 9:23 pm
gabriel
Hi everyone
I am attempting to replace the seals in the water pump. I have the cast impeller and have purchased the original water seal.
Unfortunately I broke the threaded section of the shaft when I hit it with a hammer to try and remove the impeller from the shaft.😢
The shaft is in good condition and was wondering how necessary is it to install the nut?
The cast impeller is an extremely tight fit on the shaft and I'm thinking would that be enough to to ensure the impeller doesn't move?ive heard of cases where the nut breaks off but never the impeller.
I was thinking of drilling out the remainder of the shaft and installing a screw or perhaps jb weld the broken section of the shaft all opinions
Will be appreciated.
1984 BMW k100..frame number 6228?
1992 BMW K75s
