did a throttle body change today
the tbs were progressively becoming harder to operate first thing in the morning , very hard to open ...a few finger actions at opening them with the cable adaptor cam assisted , but unsure what this action was doing to the accelerator cable , and gear set in the handlebars , long term .
perhaps during the last install I had bent the frame of the bodies out of kilter and now binding along their axis ? with the slight difference in temperature ??
so I prepared another set that I had on hand , first off adjusted the linkages that never should be touched , so that all butterflies were a gnats cock close to each other in opening ..and closing , achieved this with 4 brass roads (1/8 inch ) thick through the tb butterflies
then a cleanup of the vacuum paths including the jets , set them at 1.5 turns out on the bypass screws
then to the job at hand
a bit of oil weepage had been happening around the crank breather tube , I had not been able to successfully tighten the hose clamp around the base , letting some vapour bypass the tube ….(turned it 90 degrees and achieved full seal now)
coming out
oil weepage
soon cleaned up
going back on ,easiest way ive found is to attach the tbs to the plenum and then fit down into the head support rubbers ...its still a pain to achieve though but persistence pays
later assembled and ready to tighten up
all done ...even got the hose clamps not binding ...first try
totally surprised that with minimal suggested setting that the bike started and ran ...fairly smoothly first up
tomorrow tb balance and adjust , but the throttle control seems far smoother and responsive already from the feel..
a win I guess ...more to come
