Engine Left side cover Leak Sun Oct 25, 2015 2:41 am
xatzigiorgis
![xatzigiorgis](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
Hello to everybody.
Few days ago someone crashed on my '87 k100 while it was parked and left. When i found it out i saw that the cover has a crack (because its been hit direct at the corner it is very small) on the front lower side and there is a small oil leak ! I m thinking of opening it and try to weld it.
My questions are :
1) should i empty the engine from the oil or its not going up there while the motor is not running
2) Can it be weld or must i start searching for a new cover
3) If there is green light for the above ... must i change also the rubber between the block and the cover ?
Any help is appreciated
My questions are :
