1Back to top Go down   Starter motor wont stop............. Empty Starter motor wont stop............. Mon Jul 13, 2015 4:53 am
andyb
andyb
Hi all, a couple of weeks ago I went to start the bike in the morning to go to work, and the starter wouldnt stop.
the only way I could stop it was to rush and grab an Allen key and remove the earth lead off the engine case.
I replaced the starter relay under the tank with another, 2nd hand unit, and all was good for a week, then its done it again.  Now I'm wondering if the 2nd hand unit is also buggered or maybe the problem is lying elsewhere?
I've Looked through some of the posts.....to test the starter relay do I just put the mutli meter onto its posts and if I get 12v its fried?
Reading the posts I'm wondering should I be going into the starter motor to give it a good clean? Its used almost daily to get to work, battery is strong it must have cranked for a good 3-4 minutes while I accessed the Allen keys without slowing down.......
where else can it go wrong - almost too afraid to get this bit answered....;-)
advice on what else to check? starter switch?
thanks heaps!
AndyB
'03 K1200GT,
'88 K100 RT
Chassis number: 0097248 ; Vehicle code: 0504; Series: K589
Model: K100RT 84 (0504 (0505) Body Type: K100RT 84 (0504)
Catalog Model: ECE; Engine: (0504); Production: 1988/9
Starter motor wont stop............. 13763011
probably outside the starter switch andy
but wouldn't be a bad idea to clean the contacts ...and check that the spring is returning the pushbutton to the right place ...deteriorating plastics could let it bind a bit ...so lubricate that
more than likely the brushes in the starter is the issue ...causing big currents in the starter motor relay .... which we all know causes some welding of the contacts to happen ...in bad cases  the kit for the brushes ...( 2 bits ....plate and brush and positive brush ) aren't expensive to replace - purchase
can I add that many of us have upgraded the negative cable from the battery to the gearbox connection point to overcome the voltage drop under starting conditions ...that particular cable is woesome after many years and possibly some corrosion between the surfaces ...and breakage off some of the cores of the copper along the path ..resulting in more current being drawn .
a disassembly of the starter relay and a little light buffing of the contact surfaces might help ...be careful not to gouge big bits of contact plating out of the points contact area
hope that helps ...
and good to see you still riding the k mate ...cheers
You're right in that it's either the starter switch or the starter relay. One way of checking the starter relay follows:
Disconnect the wrires from pins 85 and 86 (red-brown and black yellow - they're the two with the 1/4" / 6.25mm spade terminals) and also pin 87 (the one that goes to the starter motor). Earth pin 86, then with another piece of wire,  briefly connect pin 85 to pin 30. Each time you do this, you should hear the starter relay make and break. It's an operational test only.
As it happens, for once I don't agree with Charlie. I think your culprit is the starter switch; quite possibly a broken return spring that's allowing it to make intermittant contact from road vibration.
So now prove me wrong... Starter motor wont stop............. 44271
Brad-Man
Brad-Man
You may want to check your battery - if it is not up to snuff it can cause the contacts in the relay to weld together...
Starter motor wont stop............. Usa-lo10
kioolt
kioolt
Dai wrote:As it happens, for once I don't agree with Charlie. I think your culprit is the starter switch; quite possibly a broken return spring that's allowing it to make intermittant contact from road vibration.
If the starter switch is the problem then the key switch would be able to turn it off.  The OP said the only way he could stop the starter was to disconnect the ground.  That equals starter relay or some short on the relay control wires (small wires) to some unknown circuit.
2004 R1150RT 186,800 miles
1991 K100LT 128,700 miles
1982 R100RT 106,900 miles
Total 422,400 BMW miles
AMA,BMWRA,BMWMOA
andyb
andyb
Thanks guys, starter button itself seems ok but i'll check it out anyway.....
Does the relay come apart fairly easy to check it? I'm thinking the starter motor route.
When I get time I'll whip it out and have a squiz at it. Let you know what I find......
Yes Charlie, she get used equally as much as the K12GT, actually I find it easier in the city traffic stop start, and I still am very attached to her Smile. Now that Ive done the 12 rivet shaft and all things on the way to it she purrs like a kitten, as she should!
By the way, is there an alternative relay we can get in Oz that doesnt cost the earth???
AndyB
'03 K1200GT,
'88 K100 RT
kioolt
kioolt
If you've got a multimeter you can check the relay while it's installed.  You can check for voltage on the coil circuit (2 small wires).  Measure the voltage across the two wires, not to ground.  Voltage should be zero when not trying to start and 12v when trying to start.  My bet is that you will find zero there when not trying to start.  Next step would be to unhook the starter wire from the relay and measure the resistance.  You should have an open circuit across the two big terminals.  If you have anything but zero at this point, your starter relay contacts are welded together.
AMA,BMWRA,BMWMOA
andyb
andyb
kioolt wrote:If you've got a multimeter you can check the relay while it's installed.  You can check for voltage on the coil circuit (2 small wires).  Measure the voltage across the two wires, not to ground.  Voltage should be zero when not trying to start and 12v when trying to start.  My bet is that you will find zero there when not trying to start.  Next step would be to unhook the starter wire from the relay and measure the resistance.  You should have an open circuit across the two big terminals.  If you have anything but zero at this point, your starter relay contacts are welded together.
Thanks for that info Kioolt!
So I can do this without the batt. earth connected yes? or else she'll be trying to start........
AndyB
'03 K1200GT,
'88 K100 RT
Do the tests with the wire fron relay to starter disconnected.
kioolt
kioolt
The earth ground will have to be hooked up for the relay test.  Unhook the starter wire, tape it up and do the checks.
AMA,BMWRA,BMWMOA
kioolt wrote:The earth ground will have to be hooked up for the relay test.  Unhook the starter wire, tape it up and do the checks.
a good suggestion
not to hard to prove andy ...  and the relay is pretty easy to open up ...once out
don't have a aussie equivalent link mate ...but young mr alby  did buy a locally sourced item at a reasonable cost from memory ... ebay sometimes can be a friend .
kioolt wrote:....
kioolt, I know you meant to say "If you have anything but infinite at this point, your starter relay contacts are welded together."
Andyb, although you're measuring resistance you're only interested in 'infinite' resistance (1 on your DMM) = contacts open. ie, open circuit = Relay good (providing there's zero voltage on the coil).
'Zero' resistance (or very small reading on the DMM) = contacts closed (welded). ie, closed circuit.
Gets a little confusing so I like to use the diode/continuity setting on the DMM. Beep means contacts closed. No beep means contacts open.
If you buy a secondhand relay best to open it up when you get it to make sure the contacts are in good condition or ask the seller to check.
Find the cause of the welded contacts before attempting another start otherwise you'll just fry the contacts again. Bad battery (pretty common), worn starter brushes or poor starter earth return (corrosion).
 Starter motor wont stop............. Austra12    Fuel:  95 Octane
kioolt
kioolt
Yes you're right Kaptain Hollister.  This stuff is second nature to me.  I guess I was tying to make sure I gave complete enough instructions that I lost sight of what I was tying to say.
AMA,BMWRA,BMWMOA
andyb
andyb
Hi, these are more like a reasonable price............Same???
Starter motor wont stop............. _1411
Starter motor wont stop............. _1510
http://www.ebay.com.au/itm/291109710293?_trksid=p2060353.m1438.l2648&ssPageName=STRK%3AMEBIDX%3AIT
And also this site looks promising for parts at a good price too:
http://www.euromotoelectrics.com/
AndyB
'03 K1200GT,
'88 K100 RT
That's the right one. Looks like a really good price.
The relay from EME will be about twice the price by the time you add shipping to Oz, but it has diodes to protect the ECU from back emf. They weren't originally like that and its not totally necessary. Just a precaution.
Did you find the fault because if you have to order starter brushes the best place is from EME.
Starter Repair Kit
andyb
andyb
Kaptain Holister wrote:That's the right one. Looks like a really good price.
Starter Repair Kit
G'day Kap. Nope, havent had a chance to get into it, the work/life balance is up the creek at the moment, so I thought I'd start looking for parts in the meantime......
Starter motor wont stop............. 797640
AndyB
'03 K1200GT,
'88 K100 RT
keep at it andy
that one should do the job
