1Back to top Go down   OH Boy!!!  Empty OH Boy!!! Sat May 23, 2015 3:00 pm
svlwolf
svlwolf
OK,  I have 3-small rubber washers and 2-Large rubber washers with a groove all the way around them, I then have a metal bushing (its not the one for the brake lever ) I have no idea where these go, any ideas
OH Boy!!!  20150524
1985 K100RS amidst customization bounce
OH Boy!!!  Usa-lo10
2Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sat May 23, 2015 3:32 pm
OH Boy!!!  Linjal10
3Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sat May 23, 2015 5:24 pm
Nice fabric! What is that pattern?
Wink
4Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sat May 23, 2015 9:04 pm
svlwolf
svlwolf
Thanks for the compliments on the bed spread :king:
The length of the bushing is 25mm, Outside Diameter is 14mm, Inside Diameter is 8.40mm
The Large Rubber Outside Diameter is about 26.5mm the inside diameter is 10.14mm and 5.45mm thick
The small Rubber Outside diameter is  16.9mm the inside diameter is 6.3mm and 2.80mm thick
OH Boy!!!  Usa-lo10
5Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sat May 23, 2015 10:12 pm
bushyintas
bushyintas
Rear ducktail fairing mount , sandwiches the fiberglass where it bolts to the frame, inside where the tool box lives under the seat.
Bushy.
Bushy
k100 RT 1988 #0095723
K100 RT 1984 into Custom Single seat.  #0024503
6Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sun May 24, 2015 1:07 am
Do you mean this?
Large Gromet #11 on the seat hinge bracket
OH Boy!!!  B0012396
Small gromet #3
OH Boy!!!  B0012382
 OH Boy!!!  Austra12    Fuel:  95 Octane
7Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sun May 24, 2015 4:01 am
k-rider
k-rider
the steel bushing could be from a rubbermounting for  a foot peg plate
k-rider
8Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sun May 24, 2015 4:13 am
Further to what Bushy mentioned, the two larger "rubbers" are in the ducktail at the rear.  They are located just in front of the rear brake light and are sandwiched in between the bracket which holds the rear wheel mudguard in place (from underneath).  Should have a penny washer on top and a 10mm lock nut will hold it all together.  The rubber is more of a vibration damper.
It is also necessary to loosen these two nuts if you wish to remove the rear plastic registration plate fitted below the rear brake light.  There are also two self tapping screws here holding it up snug.  Might want to check they are firm.
Hope this helps.
Dave.
9Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sun May 24, 2015 4:15 am
OH Boy!!!  Skjerm10
10Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sun May 24, 2015 4:17 am
k-rider wrote:the steel bushing could be from a rubbermounting for  a foot peg plate
Could also be the silencer mount.
11Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sun May 24, 2015 4:19 am
Thanks Inge.
12Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sun May 24, 2015 3:02 pm
svlwolf
svlwolf
Inge K., BINGO bushing goes in the silencer mount!
OH Boy!!!  Usa-lo10
13Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sun May 24, 2015 3:20 pm
svlwolf
svlwolf
I also assume this is what 11 and 12 would be on the parts diagram?
OH Boy!!!  20150525
OH Boy!!!  Usa-lo10
14Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Sun May 24, 2015 8:51 pm
Looks right to me!
15Back to top Go down   OH Boy!!!  Empty Re: OH Boy!!! Tue May 26, 2015 6:24 am
bushyintas
bushyintas
Thanks Inge +1 from me.
Bushy
