1Back to top Go down   Valves bent possibility Empty Valves bent possibility Fri May 22, 2015 6:01 am
VPutin
VPutin
Hi everybody,
start to repair my lady after last year accident.
Where the valve cover was broken and chain also.
So, what a chance, that valves was not bent in such case?
Valves bent possibility User1912
2Back to top Go down   Valves bent possibility Empty Re: Valves bent possibility Fri May 22, 2015 6:26 am
That chain looks intact to me. Have a closer look, but seems ok.
What worries me more is bits ending up inside where they shouldn't be.
3Back to top Go down   Valves bent possibility Empty Re: Valves bent possibility Fri May 22, 2015 6:40 am
VPutin
VPutin
92KK 84WW Olaf wrote:That chain looks intact to me. Have a closer look, but seems ok.
unfortunately it was broken. (this photo was made on accident scene, when bike was lifted up, chain was obviously broken)
sorry, but I didn't understand, was is about.
4Back to top Go down   Valves bent possibility Empty Re: Valves bent possibility Fri May 22, 2015 6:55 am
If the chain was broken then there is a very high probability there are some valves bent.
A compression test will tell if any are bent. When a valve is bent there will be almost zero compression.
Valves for those engines are expensive if you can find one. Try to find a complete engine it will be the easy way to get back on the road.
5Back to top Go down   Valves bent possibility Empty Re: Valves bent possibility Fri May 22, 2015 7:41 am
VPutin
VPutin
But, to test comprassion, I have to replace chain first?
6Back to top Go down   Valves bent possibility Empty Re: Valves bent possibility Fri May 22, 2015 9:24 am
With that much externally visible damage I would have the cylinder head off, as well as the oil pan, for a careful internal look before thinking any thoughts of spinning over the motor.
7Back to top Go down   Valves bent possibility Empty Re: Valves bent possibility Sat May 23, 2015 8:43 pm
The Pic looks like the camchain is intact and the camchain guide has been broken as well as the tappet cover, either way there must be foreign matter in the engine by now, I'd pull it apart before anything else, off with the tappet cover and the camchain cover and see what may have went inside the engine.
