1 Water/oil pump seals Wed May 13, 2015 12:18 pm
Howard64180
Today I fitted new water/oil pump seals. It was going really well until I pushed too hard on the impeller shaft to get it through the oil seal. The shaft caught in the centre part of the water seal, forcing it to sit at a slight angle. I pulled the shaft back and drew it through in the normal way. Are these water seals as delicate as their reputation? Have I possibly damaged it?
Last time I did this job I had to do it twice, when I pulled the shaft through too far.
