1Back to top Go down   1992 k100rs 16v water/oil pump seals Empty 1992 k100rs 16v water/oil pump seals Sun Sep 29, 2013 4:22 pm
Rabidchiwawa007
Rabidchiwawa007
Hello,
This is in regards to a 1992 k100rs.  It's leaking oil from that little hole on the front of the engine from the oil pump.  I successfully did this procedure on an older K100 I used to own, but am a little unsure of what I need for this one.
Do I need to order updated parts, like a new impeller, spacers, the different seals, etc.., or were the 16v bikes already designed with these?
1968 BSA Lightning
MikeP
MikeP
The impeller fitted is the updated one. Any seal you are sold today should be the correct one.
1992 K1
Rabidchiwawa007
Rabidchiwawa007
Awesome thanks.
Can someone confirm the following:
I need part #s:
Part Number  DescriptionlbQty1992 k100rs 16v water/oil pump seals InfoheaderEachTotal
 11411741870 SLIP-RING SEAL
0.04 1992 k100rs 16v water/oil pump seals Minus1992 k100rs 16v water/oil pump seals Plus
 11411460329 SHAFT SEAL - 12X25X5
0.01 1992 k100rs 16v water/oil pump seals Minus1992 k100rs 16v water/oil pump seals Plus
 11411460403 O-RING - 13,3X2,4
 11111460392 O-RING - 27,3X2,4
 11411460328 O-RING - 7-2
Total Weight:     0.05 lbsSub Total: $31.58
Here's a link to the diagram: http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51709&rnd=04302013
The diagram shows the older cast impeller for some reason, but is indeed a diagram for the '90-'92 k100rs.
Thanks!
1968 BSA Lightning
