1 ABS or not ABS Thu Jul 30, 2015 7:53 am
touchwoodsden
The chair frame and bits are back from the powder coated although I'm still waiting for all the plastic and the chair body to come back from the (different) painters.
It's been quite a while now and in spite of a few prods it still hasn't featured.
When he said he would take it on I don't think he realised how many parts he was going to have to hang up in order to paint.
I have assembled all the front brakes and the linkages on the Wasp Forks and Wheels but haven't yet fitted the brake pipes at the front which brings me to the question.
The caliper mounting which is floating on the leading link Forks moved the ABS sensor closer to the rotating Castle affair so I've had to remove it in the short term at least and will have to space it out.
However during the course of all the years I have been on motorbikes I have only ever had 2 with ABS and although they were never problematical, I never actually needed it!
The system on mine is working and it occurred to me that it might not like the floating caliper at the front very much.
So the question is whether I should get rid of the ABS and pipe the brakes indirect (easy enough to do) and flog electronic gizmos and modulators or whatever they are called on the Bay of E, or whether I should keep it. I'm inclined to get rid of it purely for simplicity. A friend of mine has simply disconnected his.
If I do get rid of it and I still stuck with that large chunk of loom and connector which goes to the control unit plug in the tail housing? I know part of it goes to the rear lights but I could always separate that.
Apart from the two canisters on either side and the taillight located control unit is there anything else that I would need to take off to flog?
One of the upsides of getting rid of the control unit of course in the tail unit is that it gives me a large "toolbox".
So, do I get rid of it or keep it? I doubt this will ever be reverted back to a solo but I do have all the original bits to do so if anyone wished. Would I be better off getting rid of all those bits (and pocketing the money) or selling them separately. I'm inclined to think that it doesn't make the bike worth much more if it's going with a load of bits which are never going to be used again.
Certainly, if I wanted a K 100 solo I wouldn't buy one kitted for the chair and convert it back.
All replies greatly appreciated.
Regards
James . N Wales
Regards
James . N Wales
