1 Electrical trouble mounting aftermarket digital speedo Wed Jun 11, 2014 3:35 pm
Adil86
Good evening everyone
I mounted a digital speedometer on my 87 K100 LT.
It contains digital speedometer, Tachometer with a pin, fuel indicator, gear indicator and a low battery warning.
The speedo turns on.
Speedometer works fine via a hall sensor and magnets on the front wheel.
I havent ridden it alot while installing the new speedo but it seems that the fuel indicator works as well.
Problem 1:
I can turn on the bike without pulling the clutch but the Neutral light does not come on, I read about installing 3 relays on the 3 gear indicator wires. Will this make the Neutral light come on? Where on the bike do i mount these relays? What are these relays called? (what do i search for if i wanna buy them)
Problem 2:
The gear indicator on the new speedo has a wire for each gear 0-1-2-3-4-5-(6) How does the 3 yellow/other colour wires connect with the 6 wires on the speedo?
The wires from the speedo are called:
N-GND
gear-1 GND
gear-2 GND
gear-3 GND
gear-4 GND
gear-5 GND
(gear-6 GND
Problem 3:
The Tachometer is wired to the black/blue wire on the bike but it does not work. It stays on 2000rpm and jumps about 500rpm up and down every once and a while.
Problem 4:
The battery warning indicator on the speedo keeps blinking. Do i have to connect the blue loading control wire somewhere on the new speedo?
I hope you guys can help me with these problems :-)
Let me know if you need more informations.
Adil
Problem 1:
Problem 2:
N-GND
gear-1 GND
gear-2 GND
gear-3 GND
gear-4 GND
gear-5 GND
(gear-6 GND
Problem 3:
Problem 4:
Adil
