1Back to top Go down   Rear shock/final drive mounting stud Empty Rear shock/final drive mounting stud Thu Apr 16, 2015 12:18 am
MLR
Doing a spline service on my K75RT. When I removed the nut holding the lower end of the rear spring strut to the mounting stud in the final drive it had seized on the stud and the stud unscrewed along with it from the final drive. What’s the best way to re-install the stud?  No mention of torquing values in Haynes (I’m reluctant to torque it in too tight for fear of cracking the final drive).There was no sign of anything like loc-tite on the stud.
1991 K75RT (since new)
Past bikes: Triumph Bonneville 650, Triumph Bonneville 750, Triumph Trident 750, Moto Guzzi T4 850, BMW K75C
Brad-Man
Brad-Man
two nuts on the stud (torqued together) to get it in and seated.  You can use loctite and stop when the effort increases significantly.
Rear shock/final drive mounting stud Usa-lo10
MLR
Thanks B-Man. Had used the two nuts torqued together thing but didn't feel comfortable about how tight I was tightening the stud into the final drive housing. Will do the loctite thing as you suggest.
dutchie
dutchie
from the Haynes manual, 51nm for the 75 models and 58nm for the 100 models
Rear shock/final drive mounting stud Torque14
Dick
K75RT 1996 Rear shock/final drive mounting stud Klettern
K100RT 1986
