1 How old is my bike? Sat Apr 18, 2015 3:52 am
Number14
I'm in the process of replacing the fuel tank after a slight leak (more of an ooze than a drip) from the old tank.
While the fairing and old tank are off I decided to check the fuel lines to find the they are dated 1985 . They've now gone and shiny new ones are fitted.
Under the airbox there was a manufacturing stamp on top of the engine block that also said late 1985 . Several other date stamps on other components are from around the same time.
None of these would be an issue except the bike is recorded as first registered in August 1988 and, on checking the VIN is noted to be a February 1987 build.
Did BMW build bikes with 18 month old parts?
