1 Oil in the drive shaft housing?? help Tue May 17, 2016 1:30 pm
dakelvinator
Hi
need a bit of help/advice/information. Today I removed the rear drive to do the spline lube on my 1990 K100lt However when i got the rear drive off the drive shaft housing (swingarm) was full of oil and I also found some chewed up rubber!! (mega bummer) But the rear drive looks fine and had plenty of oil in it and the gear box oil was nearly full and had been in it for a while by the looks of it as it was black and nasty!
I have changed the oil in the rear drive and the gearbox today. any suggestions as to what could cause this and what work is involved? I am wondering if their is a seal at the back of the gearbox that is gone if so can this be fixed with just removing the swingarm? thanks in advance K.
