1 Starter motor not turning over Tue Mar 10, 2015 3:01 am
Oliveri
Ok here it goes. My 'K' has been sitting for a while (12 months or so) while i have been doing some 'rejuvenation'. Wheels powder coated, tank polished, new handle bars, new break cylinder, etc, etc. I have started it from time to time just to keep things lubricated. I last started it a couple of months ago. The battery wasn't great when i started this project and needs replacing (new one coming tomorrow). I used a disconnected 'ok' car battery to jump start my K if required with no problem.
So yesterday i thought it was a good idea to 'kick' her over one more time to make sure every thing is working before the new battery gets installed. Connected the car battery with jumper leads turned on the ignition all lights came on, neutral, gear indicator, etc. Hit the start button but nothing, again and again. Disconnected the jumper leads and reconnected, now it appears that the neutral light, gear indicator and battery light no longer function. ???
I pulled the starter motor out and connected it straight to the battery and it works. Put it back in, hooked everything up again but nothing. No clicking of the relay when i press the start button... I tried to pull the clutch lever and i can hear the relay click but no turning of the starter motor.
i replaced all the fuses, still the same. The relays appear to be ok lights work, horn works, indicator works, fuel pump sounds like is works. But starter wont turn over and neutral light, gear indicator and battery light no longer light up. I'm at a loss and not big on electrical issues.
Please help
Please help
"Keep the paint up, and the rubber down
1988 K100RT...#0096960 ..."Heisenberg"...Status: Work in progress
