Probably a bit late now...
Search on youtube for DIY injector cleaning. Problem is that once cleaned, the flow rate might still be out unless measured.
Of course, you can buy injector service kits easily and cheaply enough.
One thing I do when "servicing" mine is to reverse flush the injector. Unless the filter is replaced on the top (use a self taping screw and pull it out) there will be debris / shite in it. A reverse flush blow it back out of the top.
Haven't worked out a good way to measure flow rate... some of you more able fabricators can work out a device that:
Uses a piece of circular wood (eg hole saw) attached to a drill on #1 speed / or drill press geared down
One the edge of the wood attach a piece of very thin metal sheet to create an eccentric edge
When spun around, the thin metal sheet creates an on / off switch for the circuit...
Circuit = 9V battery, wired to a fuel injector (alligator clips)
Top of the injector uses the tire valve, pressurised carby cleaner and straw (on youtube)
Cleaning continued accurately over say a minute and output / flow rate measured into a container.
A small piece of board could be used to secure all the bits and pieces
So at this stage of my reply, I looked on youtube and found:
https://www.youtube.com/watch?v=wF0zQCkbIr0NB: I don't think injectors are meant to be on for too long
Note comment about using a digital scale to measure weight
I still have a bag of bits from Jaycar to mount a small motor to imitate the on off action of real life.
One day!!
GF
