1Back to top Go down   Seized pannier latch Empty Seized pannier latch Wed Mar 18, 2015 10:03 am
JayceLane
JayceLane
Hi All.
Ummm, wanted to remove my pannier last night for clean up, but for the life of me I cant get the forward facing pannier latch loose.  Any clever ideas here.  I tried some force, but with the pannier box starting to flex I thought better off it.  I see that the latch is held in place by rivets, but is there another way of getting it loose, without drilling out rivets.  I have jiggled and wiggled that thing as well. Thanks in advance.
Pic of offending latch.
Seized pannier latch Wp_20115
2Back to top Go down   Seized pannier latch Empty Re: Seized pannier latch Wed Mar 18, 2015 10:33 am
WD40 might help.......rivets are easy to do.
3Back to top Go down   Seized pannier latch Empty Re: Seized pannier latch Wed Mar 18, 2015 10:35 am
Silly question but is it locked?
Seized pannier latch Ir-log1188....May contain nuts!Seized pannier latch Ir-log11
K75RTP - 1994
4Back to top Go down   Seized pannier latch Empty Re: Seized pannier latch Wed Mar 18, 2015 10:47 am
The small rectangular bit will reveal a key slot.
5Back to top Go down   Seized pannier latch Empty Re: Seized pannier latch Wed Mar 18, 2015 10:57 am
RicK G wrote:The small rectangular bit will reveal a key slot.
A wise owner would have that locked.......they have been known to open and pannier fall off.....Those one are the same ones as were on my RT when it came. Except they were broken and I had to replace those two locks. If in doubt get new ones because they rely on clipping over a couple or aluminium lumps that wear. They are the only thing stopping the pannier falling off. Also replace the plastic hinges, they split......
6Back to top Go down   Seized pannier latch Empty Re: Seized pannier latch Wed Mar 18, 2015 11:03 am
JayceLane
JayceLane
Ta daa.
I was familiar with the older type found on R bikes.
thanks chaps. Luckily i had a key.
7Back to top Go down   Seized pannier latch Empty Re: Seized pannier latch Wed Mar 18, 2015 11:49 am
JayceLane wrote:Ta daa.
That is the older type as far as K bikes go, though not the 'suitcase latch' of very early Airhead Krauser-type bags.
Glad to know it was a simple 'fix'.
