1Back to top Go down   A little bit of maintenance Empty A little bit of maintenance Mon Mar 16, 2015 9:59 am
DeRodster
DeRodster
And not before it's time
Replacing the handlebar master cylinder
A little bit of maintenance 2015-010
and fan motor
A little bit of maintenance 2015-012
A little bit of maintenance 2015-013
A little bit of maintenance 2015-014
A little bit of maintenance 2015-015
One of the motor brushes is very burnt,
Onwards and upwards
R
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
2Back to top Go down   A little bit of maintenance Empty Re: A little bit of maintenance Mon Mar 16, 2015 11:09 am
You're well stuck in now Rod. Is it growing or just a short list?
A little bit of maintenance Ir-log1188....May contain nuts!A little bit of maintenance Ir-log11
K75RTP - 1994
3Back to top Go down   A little bit of maintenance Empty Re: A little bit of maintenance Mon Mar 16, 2015 11:25 am
DeRodster
DeRodster
Ah it's short enough Will
The next BIG one is the fork stanchions
but the tricky one has been the master cylinder.
Had to 'bite the bullet' on that one and get a replacement ;-(
it's not so much doing the actual replacement
but rather the amount of bits that have to be taken off !
Still as someone said to me a couple of years ago, its a great way
to get familiar with the machine.
More anon
R
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
4Back to top Go down   A little bit of maintenance Empty Re: A little bit of maintenance Sun Mar 22, 2015 2:14 pm
DeRodster
DeRodster
So ,
Radiator fan motor replaced and radiator re-filled.
Removed bars earlier and ran a cable up them to allow me to retrieve heated grip cable.
But first I will replace master cylinder plunger /seal thingy and outer cover.
Working on the 4 heated grip connector's as i had to cut them out of their plastic housing.
Will refit in the new housing and just need to solder them and seal.
Then hopefully replace the lot and fire her up.
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
