1Back to top Go down   Split Swing arm boot Empty Split Swing arm boot Sat Apr 11, 2015 1:03 pm
audibob
audibob
Hi Guys, now my cd drive wont read my k100 manual disc, I need to know whether I have to remove the swinging arm in order to replace the drive boot. If i remove the shaft, is there sufficient room to get at it .
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Triumph T 140V Bonneville
Triumph T150 Trident
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
K100 LT current bike
2Back to top Go down   Split Swing arm boot Empty Re: Split Swing arm boot Sat Apr 11, 2015 1:14 pm
You have to remove the drive shaft housing to access the boot. You will not be able to access the boot by just removing the rear differential and drive shaft.
3Back to top Go down   Split Swing arm boot Empty Re: Split Swing arm boot Sat Apr 11, 2015 1:15 pm
There is no way to remove the forward rubber accordian boot without first removing, or sufficiently pulling back, the swingarm and final drive on a Monolever K (as an assembly is easier).
4Back to top Go down   Split Swing arm boot Empty Re: Split Swing arm boot Sat Apr 11, 2015 11:34 pm
KlaustheK
KlaustheK
Having just finished this exact project as I swapped gearboxes I can say it's not much more work to get the swing arm assembly vs just the diff and shaft only four more bolts.
1987 K100RS Klaus *sold*
1989 K100RS SE Klaus 2 *sold*
1997 K1100LT Gunter
5Back to top Go down   Split Swing arm boot Empty Split Swing arm boot Sun Apr 12, 2015 3:50 am
audibob
audibob
Thanks guys,
It will give me the chance to inspect the swing arm bearings .
Do the pivot arms need replacing at higher mileages, or can I expect them to last , providing they are lubricated and the  bearings are good.
I can also check the spline lube and inspect the clutch actuating mechanism whilst the "back end " is off.
Bob
Yamaha 90
Honda CD 175
Honda CB 360
Honda CB750 F1
Cz 175
Yamaha XS 750
R 100/7
R 80
K100 LT
