1 Test guide Mon Mar 29, 2010 2:37 pm
badgerdid
Is there a quick guide to the tests mentioned in the forums, mainly the ohm ones for the various censors.
I.e the temp censor, where to connect the meter to and what the readings should be, the airflow censor, what connections to use and what readings should be got, etc etc
I am going to be stripping mine down and checking every electrical joint etc as advised on the forum but also want to check everything as i go.
I find reference to a test, then come back to get the readings and cant find them again, would be nice if there was a list and maybe made a sticky?
Excuse me if there is already one but i cannot seem to find it. Also i cannot seem to find where or what the hall sensor is? cant you tell im new, lol
