1 Steering damper for sidecar outfits Wed Mar 07, 2012 9:15 am
Most outfits need some sort of steering damper to counter the low speed handlebar shakes.
One problem with our faired bikes is that there aren't any convenient fixing points for a hydraulic damper, so when I built my outfit I came up with this idea for a friction damper. Simply it's an O ring under the knurled bearing adjuster ring which bears on the steering column. From memory, it was about 4mm section and I used a cut down early Gold Wing oil filter O ring.
To set it up, firstly set the correct adjustment for the head bearings without the O ring in place. Then mark the position of the knurled adjustment ring with respect to the steering column (I use a wax crayon). Now fit the O ring and tighten the knurled ring to where the marks line up. This ensures that the head bearings are correctly set.
How long does the O ring last, you may ask? Well I still have the original ring in place, so perhaps I should leave it another year before giving a prediction?......That would be a nice round quarter of a century.
