1 Fuel Level Indicator Sun Feb 01, 2015 11:20 pm
G'day All, the yellow beast is now registered and goes well. BUT, the original instrument cluster (86 K100RS) had two low fuel level warning light , at 7l and 4 or 5 l. .Swapped over instrument cluster from a 86 K100RT with only one low fuel level light. The problem is that the two lights do not work on the original cluster and the light stays on permanently on the replacement cluster.Should also mention that the whole loom was replaced from a supposedly K100RS. All you more knowledgeable forumers any ideas. Thanks heaps in advance. Cheers Tom
