1Back to top Go down   rear shock tuning 101 Empty rear shock tuning 101 Tue Feb 17, 2009 12:43 pm
DRxBMW
DRxBMW
Rear Shock Tuning:
The first thing to do after you install your new shock is to set the ride height. This is accomplished by adjusting the preload on the spring. You will need a helper to take measurements while you do this.
First, with the bike on the center stand, measure the distance from the rear axle to some fixed point on the frame. Next sit on the bike and while balancing as well as you can have your assistant measure again from the axle to the same fixed point on the frame. Subtract the first measurement from the second one. If the difference, called sag, is more than about 1.5" dial in more spring preload until your sag measurement is between 1.25 and 1.5 inches.
Once you have the preload correctly adjusted, start riding the bike to get an idea where to go with the damping adjustments. These adjustments are much more subjective than the preload and you will have to ride the bike under a variety of conditions to get an all around idea of which way to go.
Compression damping controls how quickly the shock can be compressed when the wheel encounters a bump. Note the bike's behavior on sharp-edged bumps such as broken pavement and patched pot holes. If it seems to bottom too easily, add more compression damping. Go back over the same piece of road so that you can compare. If the rear end feels too harsh and you get the sense that the suspension isn't moving very much, try backing off the compression damping.
My personal preference is to use as little compression damping as possible while still preventing excessive bottoming. Rebound damping controls how fast the shock can extend after being compressed. Again observe the bike's behavior under a variety of road surfaces, throw in a few twisty roads as well. Try to sense the behavior of the rear end after traversing rolling bumps as opposed to the sharp edged ones described above.
What you are looking for is rises and dips that create a large amount of suspension travel. Try to determine if the rear end settles quickly or does it bounce a couple times? If you sense any "floating" or "bouncyness" increase the rebound damping. This may come across as a wallow or weave in fast cornering.
If you dial in too much rebound damping the shock may not be able to extend from one bump in time to handle the next one. In the case of several closely spaced bumps the rear end can actually pump down. Check this by running over a railroad track (or some other series of closely spaced bumps) a few times at different speeds. I have a perfect spot not far from my house where there are two tracks in parallel.
If after traversing a series of closely spaced bumps you have a sense that the rear gets lower after each bump or if the last bump in the series feels much harsher than the first you may have too much rebound dialed in. Back it off and try again. You won't be able to set it up all in one day, more likely you will gradually dial it in over a period of several weeks. It's strictly a trial and error process but when you get it dialed to your satisfaction, you'll know it.
Keep notes so that you don't end up going in circles and remember as a general rule, if you increaseyour spring preload, such as when loading the bike up or carrying a passenger (remember you should try to maintain that 1.25 -1.5" sag between unloaded and fully loaded) you should also increase the rebound to control the additional preload.
frothing at the throttle, Gary
1994 K 75 "custom"
K whiner #86
"darKsiders were approaching
and the wind began to howl"
http://picasaweb.google.com/DRxBMW
2Back to top Go down   rear shock tuning 101 Empty Re: rear shock tuning 101 Tue Feb 17, 2009 9:51 pm
phil_mars
Hi Gary and thank you for some really useful information.
I have to say I have not made the effort on mine but I think it is time to try. The rear shock on mine is a Koni so has infinite (nearly) preload adjustment and I believe only compression damping and is one of the few bikes I have ever owned with any sort of damping adjustment.
I got a bit nostalgic and remembered the days of Jap bikes with five preload settings but were always on 5 to make up for the lack of damping. My two previous R series were a little better but now I am spoilt for choice so I will have to teach SWMBO the finer points of suspension adjustment so she can assist.
Phil
3Back to top Go down   rear shock tuning 101 Empty Re: rear shock tuning 101 Thu Jul 02, 2009 9:50 pm
Bruce
Bruce
Hi guys!
haven't looked at my damping setting on my factory shock, does anyone have suggestions for the various settings, I don't have a factory manual for the bike. cheers b
4Back to top Go down   rear shock tuning 101 Empty Re: rear shock tuning 101 Tue Jul 07, 2009 7:08 am
phil_mars
Hi Bruce, just had a quick look in Haynes and the owners manual and there is no mention of damping adjustment just preload?
Phil
5Back to top Go down   rear shock tuning 101 Empty Re: rear shock tuning 101 Tue Jul 07, 2009 7:56 pm
Bruce
Bruce
yes, I guess that must be it, never really paid attention to it before, any suggestions or rules of thumb for adjustment?
6Back to top Go down   rear shock tuning 101 Empty Re: rear shock tuning 101 Tue Jul 07, 2009 11:17 pm
phil_mars
Hi Bruce, this is a quote from DrX's post above :"Rear Shock Tuning:
First, with the bike on the center stand, measure the distance from the rear axle to some fixed point on the frame. Next sit on the bike and while balancing as well as you can have your assistant measure again from the axle to the same fixed point on the frame. Subtract the first measurement from the second one. If the difference, called sag, is more than about 1.5" dial in more spring preload until your sag measurement is between 1.25 and 1.5 inches. "
I was able to do that on mine as it is a Koni but back in the good old days I just used to set the pre-load so that it did not bottom out going over bumps and then increased it if possible to account for a greater load.
If it is too bouncy then back it off and if it tends to "wallow" going through corners then it may mean the damping is not working too well and a new shock might be on the cards.
HTH,
Phil
