ausbrick
ausbrick
My chair lives, will post a few pics soon. Planning on building a second body, basically a large box set up for camping. Cheers, ausbrick
Great Then we can expect to see you in Eden in March then?
3Back to top Go down   Thanks for the help everyone, it's on the road  Empty PICS OF ME CHAIR Sun Jan 11, 2015 2:47 am
ausbrick
ausbrick
Thanks for the help everyone, it's on the road  <a href=Thanks for the help everyone, it's on the road  SIDECAR001_zps6df4613f" />
Thanks for the help everyone, it's on the road  <a href=Thanks for the help everyone, it's on the road  SIDECAR002_zps813dfb67" />Thanks for the help everyone, it's on the road  <a href=Thanks for the help everyone, it's on the road  SIDECAR005_zps421e2cc3" />
SO WHATS ON IN MARCH ,WOULD LOVE A RUN UP TO EDEN
looks sweet aus
happy riding !
Looks good
K100 RS
K100RS with 1100 motor Premier sidecar
K100 RT KRAUSER FAIRING
R1200GS
650 Vstrom
Go for Eden Aus. Would be good to catch up again.
Lots of good work in that outfit. With the amount of karts and outfits popping up there should be no problems carrying supplies on group rides.
how's it handling so far Aus .
Thanks for the help everyone, it's on the road  10_x_110
Hello Mr Ausbrick,
Nice looking outfit and nice boat too. Just looking at your front top mounting point: it looks a little low. Do you have any issues with the bike "settling" against the chair so far?
Schoorn.
Nice looking rig  Thanks for the help everyone, it's on the road  112350
Thanks for the help everyone, it's on the road  Ir-log1188....May contain nuts!Thanks for the help everyone, it's on the road  Ir-log11
K75RTP - 1994
Saxon7 wrote:Hello Mr Ausbrick,
Schoorn.
Hi Sean, good to see you back,
My top front fitting is at the same point as Ausbrick's, ie the top engine fixing bolt. No problems for the past 100+ K miles or so.
Thanks Paul, it's nice to be back too.
Well yours is certainly tried and tested so there'd be no issue. I've had a lot of issues with the chair attached to the Rocket and I'm looking at some mods to where the mounting points are etc.
Seeen,
Rockman
Schoorn.
One outfit I had used this mounting point. What happened eventually was that the frame cracked back under the seat, apparently because the headstem could twist a little during cornering. A higher mounting point and some bracing would help with this. In fairness though, that outfit was pounded along a lot of dirt roads which cant have helped. I expect on mainly sealed roads it would be fine. Phil
