redbeemer
Hi everybody,
I believe that the throttle position switch should click when the throttle is closed but mine doesn't! there appears to be a different throttle position switch on bikes up to 1992. Does the later (1993 on) switch click or not? The later switch is at least double the price of the early one. Your help would be appreciated as I only have a Haynes manual which covers up to 1992. Thanks
green cat
green cat
I'll have a look at my K1100LT and tell you. Otherwise i have the french manual which is a kind of haynes and if there's something about two kinds of throttle i'll try to translate you the stuff
[img]K100RS 16v 1993 Throttle position switch 3cc2228804714fdc8e93fe1f84a93706[/img][img]K100RS 16v 1993 Throttle position switch K1100l10
Hi redbeemer,
This section of the forum is to welcome new members into our group. Please post something about yourself and your bike so the other members can say hello. Your question really belongs in the Engine and transmission or even the Electrical section rather than here. That will give you the best chance of an answer as most members browse those sections and some skip the welcome section altogether. So ask away in one of those and I know you will get a better response than in this section. Anyway welcome aboard, tell us something about yourself and your bike.
I have to agree with K-Bike about selecting where to post.
The big question is do you have a Motronic or L-Jetronic system.
On the L-Jetronic there is only 2 positions (idle or full throttle) when on the motronic the TPS send the exact position of the throttle body.
If you don't know what system you have, the last 7 digits of the bike serial # will help us to determine it.
K100RS 16v 1993 Throttle position switch Frog15K100RS 16v 1993 Throttle position switch Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
redbeemer
It is the Motronic system. If the TPS is completely variably, how is it set?
