1Back to top Go down   Hi, anyone getting any rain? Empty Hi, anyone getting any rain? Tue Dec 09, 2014 6:08 am
WoodyAUK75
WoodyAUK75
Hello, I was searching for switch gear as my indicator off switch is not working, and found this forum. I've had my K75s for 11yrs, and try to ride it every day.
2Back to top Go down   Hi, anyone getting any rain? Empty Re: Hi, anyone getting any rain? Tue Dec 09, 2014 6:19 am
Greetings Woody Welcome to our little Knuthaus. If you take a seat the evening self help therapy session will start soon.
We've had a fair bit in Stanthorpe but nowhere enough yet.
If you want to come for a run up to Stanthorpe I can fix you up with the bits to fix the switch.
3Back to top Go down   Hi, anyone getting any rain? Empty Re: Hi, anyone getting any rain? Tue Dec 09, 2014 6:26 am
WoodyAUK75 wrote:Hello, I was searching for switch gear as my indicator off switch is not working, and found this forum. I've had my K75s for 11yrs, and try to ride it every day.
Hi Woody. Glad you finally found us. You have a few K-owners around your neck of the woods. Check out the 'K Series Owners World Map' on the portal page. You can add your own.
Re your blinker cancel switch. Are you sure its not working? There's a brown/white wire that returns to the flasher unit which has its own single connector under the tank (on the R/H side I think) which may have come loose or has corrosion. Check for continuity.
Yep. We've had a little rain here on the coast. Its cooled things down a little.
 Hi, anyone getting any rain? Austra12    Fuel:  95 Octane
4Back to top Go down   Hi, anyone getting any rain? Empty Re: Hi, anyone getting any rain? Tue Dec 09, 2014 6:45 am
WoodyAUK75
WoodyAUK75
What is happening is that it is not springing back out, I can't figure out where the spring is, or should be. I ran across a link here but couldn't open it. Hoping now I'm a member I can.
5Back to top Go down   Hi, anyone getting any rain? Empty Re: Hi, anyone getting any rain? Tue Dec 09, 2014 8:13 am
welcome aboard woody
6Back to top Go down   Hi, anyone getting any rain? Empty Re: Hi, anyone getting any rain? Tue Dec 09, 2014 8:32 am
Move to Killarney in Ireland - you'll get about 60 inches of rain over about 300 day of the year! Oh and we'll help fix the switch too.
I'm glad you finally found your way here. Welcome!
Hi, anyone getting any rain? Ir-log1188....May contain nuts!Hi, anyone getting any rain? Ir-log11
K75RTP - 1994
7Back to top Go down   Hi, anyone getting any rain? Empty Re: Hi, anyone getting any rain? Tue Dec 09, 2014 8:55 am
Welcome too........yep, it rains here too. Its so bad it even flows from the taps! It comes out black. But some put it in a glass and call it Guinness.....
8Back to top Go down   Hi, anyone getting any rain? Empty Re: Hi, anyone getting any rain? Wed Dec 10, 2014 10:06 pm
Welcome to our little part of the world wide web, when you elect to open the switch to clean it please do it in a plastic bag so you can keep all the little bits that fly around when opening such switches, oh don't worry they go back together just about the same as they came apart, the small difference is they'll work and you'll know "how to" Plenty of posts in here that show pics of the event when others have done it.
