1Back to top Go down   Russell Day long low seat. Empty Russell Day long low seat. Sat Nov 29, 2014 11:02 pm
I puchased this off a breaker recently, sight unseen, I didn't realise it was a low seat version. Iv'e tried it on the bike and I would like to use it for a bit before deciding on keepin it long term. Any suggestion appreciated. I have an offer of the Plastic tank adaptor from Aus, do I need other bits?
Russell Day long low seat. Russel11
Russell Day long low seat. Ir-log1188....May contain nuts!Russell Day long low seat. Ir-log11
K75RTP - 1994
2Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Sat Nov 29, 2014 11:07 pm
Tank mounting parts for the pad, if not included.
Seat mounting parts which is mounted on the bike, not the seat, if not included.
3Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Sun Nov 30, 2014 12:51 am
The Russel seats are uggly, but.... They are very comfortable.
I have a day long model on the solo K100 and I would not replace it with anything else.
Russell Day long low seat. Russell
What is the secret of the comfort? Pound/square inch (PSI)!
These seats are very wide and the weight of your body is spread over a big surface. The difference with other aftermarket seats are the side wings.
This seat would not be adequate with the sidecar because I am always moving/shifting my body when turning. (My Corbin on the sidecar is already worn after only 2 years)
Russell Day long low seat. Frog15Russell Day long low seat. Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Sun Nov 30, 2014 6:04 pm
ReneZ
ReneZ
Bert, could you show how that seat is fixed to the bike? I have one as well, but not fitted yet as it seems to need different hardware (the seat came without except for a little plexiglass block. Thanks!
Rene
BMW K100 - 1985 (0030029) Scotland Russell Day long low seat. Rain
5Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Sun Nov 30, 2014 8:00 pm
ReneZ wrote:Bert, could you show how that seat is fixed to the bike? I have one as well, but not fitted yet as it seems to need different hardware (the seat came without except for a little plexiglass block. Thanks!
I use the standard K100 hinges.
Russell Day long low seat. Img_0113
and here is how you worn a Corbin in 2 seasons (This is the result of riding the sidecar a bit too rough)
Russell Day long low seat. Img_0114
6Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Sun Nov 30, 2014 8:58 pm
Crikey Bert You must have toughened pants!!
Thanks for the tips Inge and Bert.
Is you Russell a low seat too Bert?
K75RTP - 1994
7Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Sun Nov 30, 2014 9:24 pm
88KE wrote:Is you Russell a low seat too Bert?
It looks like Bert have the standard model............
I would guess that your low version needs the same mounting parts as the
BMW low version, and it's intended to be a straight swap.
8Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Sun Nov 30, 2014 9:30 pm
88KE wrote:Crikey Bert You must have toughened pants!!
My pants are BMW and they don't show any wear. Only the seat.
This is what happen when you always shift your body weight to keep the sidecar on the ground.
About the Russel, this is a standard one. It's higher than a stock seat, and even if I am 6' tall, I barely put my feet flat on the ground.
If you are under 6ft, do not consider the standard seat but at least the low one.
I had stock seat, BMW comfort seat, Corbin and Russell. The Russell is the best of all.
CF
9Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Mon Dec 01, 2014 1:09 am
Rene, if yours is an original low seat base it will have a D ring at the front and two slots on either side up towards the rear and no other mounting points.
If that is the case you need all THESE bits, minus the seat
Used - Low seat kit | SEK08373
10Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Mon Dec 01, 2014 12:44 pm
ReneZ
ReneZ
Thanks Rossko, mine is a standard, not a lowered seat. Still looking for pics/info as Bert's picture didn't show where the little block goes. Any info appreciated Very Happy
Rene
11Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Mon Dec 01, 2014 11:45 pm
ReneZ wrote:Thanks Rossko, mine is a standard, not a lowered seat. Still looking for pics/info as Bert's picture didn't show where the little block goes. Any info appreciated Very Happy
What little block are you taking about?
12Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Tue Dec 02, 2014 12:15 am
ReneZ
ReneZ
I'll try to take a picture, but it'll be over the weekend.
Rene
13Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Fri Dec 05, 2014 11:46 am
I've had an offer of the rubber bit for the tank (dunno if he has the rest) from a bloke in Sydney off the FB page called Jono, I don't know if hes on here. Does the low seat lock in with the front ring? So I'm guessing to lift it you do so from the back?
K75RTP - 1994
14Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Fri Dec 05, 2014 12:04 pm
You lift the seat in front and slide it forward to release it from the rear hooks.
About the rubber part on the tank, did read somewhere that it only fits the K75 tank.
.....I would guess this is related to mounting lugs for the battery covers, which
isn't present on the K75 models.
15Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Fri Dec 05, 2014 10:07 pm
If you want some detailed pics of the low seat and bits, let me know
Looking at my setup, the rubber tank cover fits both 100 & 75 tanks.
The main difference between the tanks that I can see is underneath at the seam. The 75 tank is narrower at the rear and as Inge said the75 tank is missing the rear cover mounts.
16Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Fri Dec 05, 2014 10:11 pm
The rubber part on the tank will fit any tank.  I've got one on my K100 sidecar.  It doesn't use the sidecover mounts at all, there is a stick on mount that goes at the rear and a stick on mount for each side to hold the sides of the cover in place, plus a circular clip that clips to the frame tubes on each side for the lower section.
'93 K1100LT
Russell Day long low seat. K-dogs10
17Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Mon Dec 08, 2014 1:58 pm
rosskko wrote:If you want some detailed pics of the low seat and bits, let me know
Cheers Rosskko - that would be super help. there isn't one local I can look at in the flesh. It would help my flea baying enormously.
Will
K75RTP - 1994
18Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Thu Dec 11, 2014 3:01 am
Low seat bits.
This shows the two rear mounting clips/lugs/things. The rear of the seat has a slot in each side on the base. You slide backwards so these go into the slots on the seat.
Russell Day long low seat. Dsc_3411
The front mount. This is in three parts. The main part goes on top of the efi holder (no longer an underseat tray) and under the frame. The four allen bolts hold the top clamps and secures it to the frame.
The release mechanism is via that metal rod on the left side.
Russell Day long low seat. Dsc_3412
This lever is attached to the other end of the metal rod. You push it down, it pulls the rod and releases the front of the seat
Russell Day long low seat. Dsc_3413
This is how the rear of the tank rubber is held on. The clips just slip over the frame. They have two small screws holding them on. My second rubber surround has them broken off. It would not be too hard to re make the clips with a bit of spring steel.
Russell Day long low seat. Dsc_3414
Another view of the locking mechanism. And the underseat tray thingy
Russell Day long low seat. Dsc_3415
The rubber mounted to the tank
Russell Day long low seat. Dsc_3422
The rubber attachment point. The brown smudge on the right side of the tank is where the side mounting clips should be if this bike had them fitted. They were gone before I got the bike.
Russell Day long low seat. Dsc_3423
The surround on a K75 tank.
Russell Day long low seat. Dsc_3416
Same surround on a K1100/K100 tank
Russell Day long low seat. Dsc_3417
Rear slots on the seat.
Russell Day long low seat. Dsc_3418
Front locking ring
Russell Day long low seat. Dsc_3419
The seat and tank surround on the 1100. Perfect fit for a short arse like me.
Russell Day long low seat. Dsc_3420
Tank mounting parts and seat lock/release lever. (sorry, but you can't have them)
The big flat one sits at the back of the tank and the rubber bolts to it.
Two triangle bits go on the sides of the tank and the rubber surround has a slot that slides into the gap and stops it flapping in the breeze.
Russell Day long low seat. Dsc_3421
19Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Thu Dec 11, 2014 10:40 am
Thats a great Map of the bits I need Rossko, thanks.
I've got a Rubber pad from the UK for just £15. So its efi holder and the other the clips and release machanism I need. Smashing. Some are of the opinion it will be too low down bum for me (5'11" or 1.79m), we'll seeRussell Day long low seat. Smooni10.
Thanks again.
K75RTP - 1994
20Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Thu Dec 11, 2014 10:58 am
Russell Day long low seat. Ir-log10
 ;BMW; K1200RS Red
21Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Thu Dec 11, 2014 10:13 pm
Cheers Simon - I never think of James Sherlock as I've never bought from them! that gets me closer!
K75RTP - 1994
22Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Fri Dec 12, 2014 9:09 am
zach_ross
zach_ross
I am converting my K75S lowseat and have all the parts for the lowseat available if you are interested, unfortunately there is a tear in the seat.
Take a look https://www.k100-forum.com/t9053-bmw-k75s-fairing-and-other-parts
Silver 1987 K75S
23Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Fri Dec 12, 2014 1:02 pm
zach_ross wrote:I am converting my K75S lowseat and have all the parts for the lowseat available if you are interested, unfortunately there is a tear in the seat.
PM Sent Zach.
K75RTP - 1994
24Back to top Go down   Russell Day long low seat. Empty Re: Russell Day long low seat. Fri Dec 12, 2014 3:09 pm
Steve M
Steve M
Hi 88KE,
When I got my 84 k100RS the standard seat cover was ripped so I took the easy way out and had 3 inches shaved off the standard sponge by a local upholsterer and had a new cover made. £45.00 job done. Then had a holiday 1500 mile round trip with no problems.
Cheers,
Steve.
