Adding extra gauges - Oil pressure - Volts....... Mon Nov 24, 2014 5:27 am
Mark K Boy
![Mark K Boy](https://2img.net/u/4211/29/48/93/avatars/3594-24.jpg)
![Gold member Gold member](https://i.servimg.com/u/f80/11/71/56/74/bmw-3s10.gif)
I like the idea of Oil Pressure gauge.......
Volts help if you use a power take off (I will make a separate post of this).
Mods have been done on a K1100RS 1993......
![Adding extra gauges - Oil pressure - Volts....... 45db48aef2a184a47cd10cf75e36d13f](https://2img.net/h/media-cache-ak0.pinimg.com/originals/45/db/48/45db48aef2a184a47cd10cf75e36d13f.jpg)
![Adding extra gauges - Oil pressure - Volts....... 7aae7612acc6a0fb6536c91cce7834bb](https://2img.net/h/media-cache-ak0.pinimg.com/originals/7a/ae/76/7aae7612acc6a0fb6536c91cce7834bb.jpg)
If you need a more exacting break down I will be happy to answer your questions, basically, I am running this off where the original sensor whole that comes out of the block, it fits - thats the good news.... - and, yes - my fairing covers this all......
So I get to keep my dash board warning light, plus........
![Adding extra gauges - Oil pressure - Volts....... 6ada168c71f6857452fe34f2dad507a5](https://2img.net/h/media-cache-ec0.pinimg.com/originals/6a/da/16/6ada168c71f6857452fe34f2dad507a5.jpg)
I replaced the fuel and temp gauges with matching VDO's as well (Sorry if that offends the purists out there, "They are still German!")
I have also replaced the bubbles with blue LEDS ($AU3.50 each) as well as the speedo and tachometer - looks cool....... More photos to come........
Foot note.....
Do not use brass fittings.....
Some of the more educated will maybe give you a reason way however from my end..... they crack leading to a not so plesent ending.....
