1 Heartbrake & the second hole? Sat Nov 08, 2014 3:09 am
Oliveri
I had a small leak on the front brake cylinder and was about to order a new seal kit. But then i noticed that ‘someone’ (previous owner) had screwed with the banjo bolt & fitting.
It’s just ‘all bad’ now (technical term). As I heavily rely on good working brakes. I need a dependable version…This is a shame as the cylinder itself is in really good condition.
While cleaning it (before i discovered the 'above shown') I noticed a second hole that appeared to be blocked…don’t laugh. I just can’t tell if it should be a hole through and through or not?
Please put me out of my misery and share your wisdom, then laugh.
"Keep the paint up, and the rubber down
1988 K100RT...#0096960 ..."Heisenberg"...Status: Work in progress
