1 Frame welding: What to disconnect? Sat Nov 01, 2014 2:16 pm
fearghal
hey there forum, i've done some research and read that its advised to disconnect the ECU and BOTH battery terminals before doing any welding on the frame of these bikes.
a couple of questions - is that FOR SURE all you need to disconnect? to be extra sure i don't fry something is there anything else i should be disconnecting?
also, in terms of unplugging the ECU - where is the best place to do that?
thanks!!
thanks!!
