1Back to top Go down   doubt (FENDER SWAP) Empty doubt (FENDER SWAP) Wed Oct 29, 2014 3:17 pm
paconick
paconick
Hi there folks, any advice for going from this front fender ...
doubt (FENDER SWAP) Eva7aza5
to something like this?
doubt (FENDER SWAP) 1617388_417307691747385_572470463_o
doubt (FENDER SWAP) 1496037_262515187239756_2016038381_o
If I remove the piece between my front fender will it modify bike's stability?
thank you very much
2Back to top Go down   doubt (FENDER SWAP) Empty Re: doubt (FENDER SWAP) Wed Oct 29, 2014 3:46 pm
paconick wrote:If I remove the piece between my front fender will it modify bike's stability?
The bridge between the top of the sliders is there to reinforce the fork,
by removing it you will have a weaker fork.
3Back to top Go down   doubt (FENDER SWAP) Empty Re: doubt (FENDER SWAP) Wed Oct 29, 2014 3:52 pm
Comberjohn
Comberjohn
On my last K100RT I changed the forks to the same as yours. Couldn't get the originals to keep their oil.
On the previous K100LT, I installed a tubular fork brace.
In both cases, I BELIEVE that I noticed that the front end was more stable. But imagination can play tricks.
My feeling would be to keep some type of fork bracing.
Unless you're after looks rather than function?
Life is not a rehearsal.
2010 VFR 1200F DCT
2010 R1200GS(gone)
1986 K100 Silver(gone)
2012 K1600GT(gone)
1984 K100 Red(gone)
4Back to top Go down   doubt (FENDER SWAP) Empty Re: doubt (FENDER SWAP) Wed Oct 29, 2014 3:52 pm
paconick
paconick
thank you very much
5Back to top Go down   doubt (FENDER SWAP) Empty Re: doubt (FENDER SWAP) Wed Oct 29, 2014 4:07 pm
Some of the reason for this fork brace is that the traditional F&S fork have
damping in both legs, the sport version (like yours) have damping on only
one side.
6Back to top Go down   doubt (FENDER SWAP) Empty Re: doubt (FENDER SWAP) Wed Oct 29, 2014 4:42 pm
When I first got mine it had b*ggered Ohlins forks on it. Adding a fork brace definately improved the handling but it wasn't until I went to F&S with Hagon progressive springs and the fork brace that the handling was transformed. So, yes, I'd keep the fork brace. It does make a difference if you're pushing the bike hard.
