1Back to top Go down   1985 K100 RT  Waterpump Rebuild?? Empty 1985 K100 RT Waterpump Rebuild?? Sat Apr 03, 2010 9:20 am
sprocket
Waterpump Rebuild??
1. How Much approx for rebuild kit?
2. How hard is it to remove?
3. How much average time involved?
I know someone here has done this and any help is appreciated...
Thanks.
Sprocket
Ohio 1985 K100 RT  Waterpump Rebuild?? Icon_biggrin
2Back to top Go down   1985 K100 RT  Waterpump Rebuild?? Empty Re: 1985 K100 RT Waterpump Rebuild?? Sat Apr 03, 2010 9:30 am
Ned
Ned
1. see kit: http://www.motorworks.co.uk/bmw/products/product.php?f=i&code=BA_15_40_GA_75&shnew=New&model=K75%2F100%2F1100&shnewcode=15∂=Cooling&sub_part=Oil+and+water+pump+parts&modelcode=40&partcode=GA&source_code=BA_15_40_GA_75&header_text=&header_text_image=0
2. easy
3. never did it, but see Bert's site. There was also a Youtube(?) video on this. One of our members posted it recently. Could be on the flyingbrick forum.
3Back to top Go down   1985 K100 RT  Waterpump Rebuild?? Empty Re: 1985 K100 RT Waterpump Rebuild?? Sun Apr 04, 2010 7:42 am
Sproket,
The download page on this forum has so much information......
Here is a complete page with pictures and explanations on How to rebuilt the water pump
Here is what the download page contains:
Bob's BMW parts price list (2005)
EFI & ELECTRONIC IGNITION
troubleshooting the EFI / Motronic
Airflow principle of operation
Engine not starting - Troubleshooting chart (PDF)
LE Jetronic troubleshooting flow chart
LE_Jetronic testing (PDF)
LE Jetronic notes (PDF)
LE_Jetronic (PDF)
Electronic Ignition connector layout
Fuel injection connector layout
Spark plugs and classic vehicle (PDF)
Motronic 1.3 internal:
LE-Jetronic internal
ELECTRICAL:
K100 (1985) color electrical Schematic (PDF)
Electrical tray layout
Testing the Hall sensors (PDF)
Flasher unit Internal diagram
Left hand switch (High-low beam) repair
Right hand switch repair (German but good pictures)
Electric windshield wiring
Gear indicator schematic
Headlight upgrade diagram
Heated grips diagram
RFI Suppression Capacitor
Starter and load shed relay
Fixing the speedo (part 1)
Fixing the speedo (part 2)
Fixing the ignition switch
Neutral light not working
Bulb monitoring unit
Temperature switching unit
Under tank Connectors
Fuse box layout
Replacing alternator brushes
Instrument cluster plug
Selective Electrical diagrams
MECHANICAL & MAINTENANCE
K100 (2V) Bearings cross reference (FAG - SKF)
K100 routine maintenance (PDF)
K100 Service info (PDF)
K100-K75 Haynes manual (PDF but compressed)
K100 Valves adjusting tool (PDF)
K bikes - How to....(PDF). This is a compilation of articles from IBMWR
Replacing the engine output seal
Fixing the oil/water pump
Fixing the transmission
Greasing the splines and Result of lack of grease on the splines
Replacing the fuel filter
Opening the fuel pump
Fuel pump replacement
Replacing the starter motor brushes
General
English/German dictionary (related to bikes)
K1100LT shop manual
K100 restoration project
Serial Numbers and Production Date (PDF)
1985 BMW color chart
US-Canada BMW dealers location (POI for Garmin) (ZIP File)
Birth of the K100
1986 K100 Press Release
1990 K100 Press Release
1990 BMW K bikes advertisement
1990 K1 advertisement
1990 advertisement (K & R)
Rider 02-1991 K100rs test
Speed calculator (XLS made by Roy Shapira)
K100rt data sheet (PDF)
K100 upgrades (PDF)
Other general infos and tips
Removing scratches on a windshield
Fairing fibreglass repair (Italian)
French:
Electricite (K75-K100)
K75 & K100 maintenance
K75 BMW training part 1
K75 BMW training part 2
K75 technique
Jet-Tronic fuel injection
1985 K100 RT  Waterpump Rebuild?? Frog151985 K100 RT  Waterpump Rebuild?? Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
