1 Gear Indicator and Neutral Light mystery Tue Nov 04, 2014 3:58 am
floyd
Have just installed a new set of odometer gears.
Had to open the instruments a few times.....as I was missing a gear and had to wait for it to finish the job.
Before opening the instruments this time around (I have been in there many times before) the GPI and neutral light were functioning 100% fine.
After reassembly the other day the gear indicator would only show 1 3 and 5 as I went through the gears.
After todays reassembly there is nothing at all on the GI lcd and no neutral light....
GPI switch tests fine with a multi meter through the gears....
there is continuity through the loom from switch to instrument connection socket...
When I jump all 4 wires on the switch end of the wiring loom (to simulate neutral) nothing happens.
all connections cleaned with deoxit
Any ideas?
Based on Ducks write up here looks like the GPI circuit board may be gone....
Any ideas?
