1Back to top Go down   Management EFI K75 Empty Management EFI K75 Sun Oct 26, 2014 7:14 pm
Just a quick one, does the EFI send separate to the injectors or all together?
Management EFI K75 Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
2Back to top Go down   Management EFI K75 Empty Re: Management EFI K75 Sun Oct 26, 2014 9:01 pm
They all fire together
3Back to top Go down   Management EFI K75 Empty Re: Management EFI K75 Sun Oct 26, 2014 10:45 pm
I've never quite figured how that works, mainly because I don't know much about fuel injection. In theory, that means it takes four squirts to fill a pot. What did I miss? Does that explain the long inlet trumpets in that they act as a reservoir to stop air movement from dragging the stored fuel from one pot to another?
4Back to top Go down   Management EFI K75 Empty Re: Management EFI K75 Sun Oct 26, 2014 11:38 pm
On a K75 the injectors fire at the firing of #3 cylinder(which fires at each rotation) and the K100 at the firing of #2-#3 so apparently get only 2 squirts per cycle
5Back to top Go down   Management EFI K75 Empty Re: Management EFI K75 Mon Oct 27, 2014 2:30 am
k-rider
k-rider
so in other words ,the 2valve k100 also fires all of the injectors ,one time per revolution of the crankshaft Very Happy
k-rider
6Back to top Go down   Management EFI K75 Empty Re: Management EFI K75 Mon Oct 27, 2014 3:38 am
Yep you got it
7Back to top Go down   Management EFI K75 Empty Re: Management EFI K75 Mon Oct 27, 2014 6:28 am
Thanks (Rick) now I will have sweet dreams.
Want to make an adapter to log ignition and injection (winterproject), but have to know what to measure/log Smile
8Back to top Go down   Management EFI K75 Empty Re: Management EFI K75 Mon Oct 27, 2014 11:17 am
Right - that makes sense. Four-strokes... (no headslap smiley)
9Back to top Go down   Management EFI K75 Empty Re: Management EFI K75 Mon Oct 27, 2014 6:56 pm
ReneZ
ReneZ
He WD, has been done by a bloke on another forum. Can't remember which one, but will let you know.
Rene
BMW K100 - 1985 (0030029) Scotland Management EFI K75 Rain
10Back to top Go down   Management EFI K75 Empty Re: Management EFI K75 Mon Oct 27, 2014 9:00 pm
Maybe Wmax351's MPGuino on Motobrick Rene??
11Back to top Go down   Management EFI K75 Empty Re: Management EFI K75 Mon Oct 27, 2014 9:17 pm
Sounds interesting, I'll keep watching Smile
12Back to top Go down   Management EFI K75 Empty Re: Management EFI K75 Mon Oct 27, 2014 10:37 pm
Max is a member here "Wmax351"
13Back to top Go down   Management EFI K75 Empty Re: Management EFI K75 Tue Oct 28, 2014 8:35 am
ReneZ
ReneZ
Indeed, that's the one! :-)
Rene
