Kyle10
Kyle10
"BMW Gasket (62111459232) is used in Instruments assembly..."
I'm getting order 'corrections' from every house I order from. Item discontinued.
While repairing a burned out bulb I found that the original gasket is showing its age; cracked, threatening to disintegrate altogether (not unlike myself).
Any ideas for a replacement? I tried razor cutting a gasket from my wife's yoga mat (not recommended) and made a hash of it.
#7
Hen's teeth: Instrument assembly gasket Gasketcase_zps2e26477f
(sorry for bold font; can't get the %&*# thing to appear otherwise)
1985 K100rt 0052183
1983 Honda VF750 007713
Most bearing suppliers (in the UK at least) stock 'O' ring rubber in various diameters.
 For the instrument gasket the ends of a length of such material can be super-glued together.
You might find 2mm diameter 'O' ring rubber on e-bay.
Just looked for O ring cord on e-bay and got over 1500 results.
Last edited by sidecar paul on Thu Sep 11, 2014 3:59 pm; edited 1 time in total (Reason for editing : Added the O ring cord bit)
www.motorworks.com. I got one from there about six months ago.
japuentes
japuentes
Been using the super glued o´ring rubber for many years on similar applications with no issues.
Best regards
JAP
Hen's teeth: Instrument assembly gasket 2854237993 1988 K100RS SE/ABS
Kyle10
Kyle10
2mm rubber super glued together. Ah, the simple solutions...
THANKS!!!
(Dai, I couldn't get link to function)
1985 K100rt 0052183
Number14
Number14
These Guys have them in stock but postage to Canada May make it a bit costly.
Avenger GT
Avenger GT
Kyle10 wrote:2mm rubber super glued together. Ah, the simple solutions...
THANKS!!!
Link should be www.motorworks.co.uk
That serves me right for dashing off a reply while on the way out of the door!! Thanks, AvengerGT.
