51 Re: Testing Temperature Switching Relay Tue Nov 24, 2020 5:56 pm
costellon
Thank you for your reply Laitch.Laitch wrote:What is the problem you're trying to diagnose, or the goal of your testing?costellon wrote:Update: Replaced temp switching relay with a known working unit and same result - no fan or light when E pin is grounded. Anyone care to comment or offer any advice ?
I will begin again. During normal operation I have no cooling fan or temperature light. Grounding the wire at the coolant sensor should cause the fan to rotate and light to illuminate - but it doesnt. This wire comes from pin E on the temperature sensing relay.
As I have explained in my previous posts - the fan spins when I put positive power to pin A2 on the temperature sensing relay - so THATS getting power and functioning, also the temperature light illuminates when I ground pin A3 to earth, so THATS also working ..... but - and this is the important "but" - when I ground pin E of the temperature sensing relay I get nothing - when I should have the fan spinning and the temperature light illuminated.
According to the title of this thread - that should be indicitive of a bad temp sensing relay - but I have swapped the relay out with 2 unknown and 1 fully functioning relay - and still I neither have a fan spinning or light lit when I ground pin E ....... THAT IS - My cooling fan and temperature light do not function when the engine goes above normal operating temperature and my bike will boil over if I allow it to run when stationary - why is this happening and how do I fix it ?
If when grounding pin E and nothing happens re fan and/ or light is indicitive of a bad relay - and I have changed said relay with a fully functioning unit why are my light and fan still inoperable on grounding pin E ???? The problem is quite obviously not the relay but something else ..... but what ????
Pin E on the temp sensing relay is dead as a dodo - why ?
Thankings
