Aftermarket fuel level sender replacement float Fri Aug 29, 2014 4:46 pm
![duck](https://2img.net/u/4211/29/48/93/avatars/3060-34.jpg)
![Life time member Life time member](https://i.servimg.com/u/f80/11/71/56/74/bmw-5s10.gif)
BMW doesn't sell the FLS float as a separate part so if yours floods then you are SOL or left with improvising. Saw this on FleaBay and bought one to see if it would work.
Omix-ADA 17729.01
Results: The base diameter is a little wider than OEM but it does fit in a K bike FLS. It has a larger volume and is taller so your fuel gauge might not register totally full when it hits the tank at the top. It is also a bit more bouyant which means it may give slightly more optimistic readings than the OEM "ping pong ball."
About $8 shipped on FleaBay in the US.
Omix-ADA 17729.01
